KWeld vs Arduino Spot Welder
sacko
Kent, United Kingdom
The KWeld is over €200 delivered in comparison to the €120 Arduino kit.
Are there any advantage to the KWeld?
Both look good for the money, but struggling to understand the price difference.
https://malectrics.eu/product/diy-arduino-battery-spot-welder-prebuilt-kit-v3/
https://www.keenlab.de/index.php/product/kweld-complete-kit/
I have the arduino version 2 and it works excellent, the newer version (ver 3) runs on a lipo pack, like the kweld (that was one of the differences). The version 3 also has a better more informative LED screen, the builder he is always upgrading the welder.
But to get performance out of them you need heavy thick probe cables (i'm using 6 gauge pure copper welding cables). Big heavy cables lets you get more amps to the tip of the probes at lower power settings. You can work nonstop. With the thinner cheap audio copper clad cables you have the crank up the power setting to get good results, high power settings and your cables will get hot, you can only do a few tabs before the cables get too hot to hold. Highly recommend pure copper especially if you got alot of cells to do. You can read some threads here in this forum about poor performance from tab welders, and its all due to the probe cables being too thin or not using pure copper.
I been using my welder with a 28ah agm battery and works excellent. The price of arduino welder is very good. On mine I have the power setting low, to get good welds using 0.15 nickel strip, and I have power to spare. Its not underpowered thats for sure. Even though it ships from germany I got mine in a week all the way to california.
I seen good reviews on the kweld too, but they both seem to work the same. As long as they can weld tabs, thats all that matters.
This is a picture of my arduino its not pretty but it does its job. On this one I have the older 8 gauge copper clad probe cables, they got very hot during use. Also version 2 only had a single LED, unlike the newer model. also the newer version runs off the 12 volt battery/lipo pack, this version I had to have a seperate power source to run the arduino. My improvement was instead of foot pedal I have a momentary switch on the actual probe that I use. I use xt90 connectors to connect to my 12 volt battery, its more convenient for me doesnt affect performance. No programming needed, just get it, connect the wires, and you can start to weld, just start at the lower settings until you get good welds, too high setting and you damage the thin nickel strip. I done 2x 80 cell lifepo4 battery packs so far with this welder and works as advertised.
Many thanks for the feedback! Much appreciated.
I only have a couple of small 13s4p packs to make, and the Arduino looks to fit the bill nicely.
I was planning to purchase the 10mm2 probes that are in the shop, worth purchasing something elsewhere?
In my understanding, KWeld is discharge energy based welder, it does not need 2 pulses and welds will be more consistent, as they do not depend much on contact and time consistency, every weld receives same amount of energy, time is the variable.
Time fixed welds can vary from one to other because of current path inconsistencies, caused by varying pressure on the tab, distance of electrodes, cleanliness of the weld patch, some of those issues are fixed with 2 pulses, where 1st is to clean and clear the path, but there is no guaranty that every weld receives same amount of energy at the end.
If it was me I would get the 6 gauge copper cables I bought 10 feet (5 feet black/5 feet red) , the probes themselves you can make with 10 or 12 gauge solid copper wire, you only need about 3 or 4 inches.
This is where I bought on ebay maybe you can find something similar in your area. It cost me 13 dollars for the wire, so it wasn't that expensive.
TEMCo 6 Gauge AWG Welding Lead & Car Battery Cable Copper Wire | MADE IN USA
Maybe other people who use the arduino probe cables can mention if they get hot during use. Too much heat and you will have to take breaks when building your battery pack to let the cables cool down. Also the thinner cable will jump around when you press the button to do the tab weld, with the 6 gauge cables it was almost non existent.
If you get the arduino probe cable they will be ready to go, 6 gauge you will have to put them together yourself. Its not hard but its extra work but the increase performance is excellent. I googled 10mm2 cables, that converts to 8 gauge cables, and in the website it says they are welding wires so they might work. My original 8 gauge I was using was copper clad audio wire.
