BoldClash 6 cells charger
yabert
Hi
I'm looking to use this really simple charger : http://www.boldclash.com/boldclash-p01-whoopower1s-lihv-lipo-charger-switchable-charging-board-max-1a-mcpx-mcx-molex-charge-6-battery-black-p129.html
You just plug it and it charge cells connect to each port up to 4.2V or 4.35V.
This charger is design to charge a single cell on each port.
How can I charge a 6 cells battery with this charger?
What will append if I connect a battery on this charger? It will blow?
I would like to use this cheap, small and low power charger with 6S battery or even 12S battery on project when battery is not use regularly (mower, e-bike, etc). The kind of projet where many hours or few days of charge is not a problem.
Let me know
Thanks
I know it's design to charge 1S cell on each of the 6 ports.
But this one is like 6 chargers and that is the difference with a 6S charger who is a single charger.
The point is probably to know if each of the 1S charger is isolated from the others.
Or, is it possible to isolate each 1S port from the others?
If it's not possible, I would like to have suggestion for a really simple 6S charger.
By really simple, I mean a charger integrated in the battery with a single act to acivate it (like connect a 120V plug in the wall).
To me, a power supply linked with a 6S BMS fix on the batterie is more conplex than the idea I have of the Boldclash.
Suggestion are welcome!
