Mixing lipo and lithium ion batteries
Lithium ion batteries have high specific energy and lipo have high c rating (high power). Is it possible to put lipo and lithium-ion batteries in parallel if they are at the same voltage and protected by charge control or BMS circuitry? This would give you a battery that has high energy density, but can also deliver short bursts of high power. The lipo would charge up from the lithium ion then deliver high power when needed the way capacitors are commonly used. It would be isolated from the circuit by transistors which would control charging and discharging.
Re: Mixing lipo and lithium ion batteries
Yes, its possible. Depending on use and diffefence in cell performance, you might not even require the control circuitry you describe.
I am running a 36S LiPo woth 43S LiFePo4 for 18 months with no issues.
I have also run 8S LiFePo4 with 11S LTO for 8 months with no issues.
No control circuits for either.
eBike: Q100H on 16S with Phaserunner FOC Controller
eMotorscooter: Vectrix VX-1 Died... Electrified Ninja in Progress!
eCar: Mitsubishi Outlander PHEV... Warramty expired. Still not game!
eHouse: 6.2kw On-grid solar with battery backup coming soon!
After 5 builds, the best advice I can give, is start with high quality products. I prefer http://www.ebikes.ca
Sure. I've done it with both Lipo+LiFePO4 and Lipo+NiMH. As long as you make sure the voltage ranges and charge/discharge rates are within the safe limits for both batteries, you are good. You will not get good balance (i.e. the discharges will be neither balanced per pack nor consistent across the discharge curve) but you will get significantly more energy.
Well, not quite. You have to make sure that both batteries can handle the max discharge rate. But if both are OK with the max rate, you will definitely see more power due to the reduced ESR.This would give you a battery that has high energy density, but can also deliver short bursts of high power.
That's completely different, and is way different than putting two batteries in parallel. And will generally reduce both battery life and total power. I'd advise against that.The lipo would charge up from the lithium ion then deliver high power when needed the way capacitors are commonly used. It would be isolated from the circuit by transistors which would control charging and discharging.
--bill von
I need help connecting my existing 16S2P 48V Nissan leaf LIPO battery banks to a new 16S2P 48v LIFEPO4 prismatic cell banksSunder wrote:Yes, its possible. Depending on use and diffefence in cell performance, you might not even require the control circuitry you describe.
Thank You
Sent from my Pixel 4a using Tapatalk
Possible. Yes
But they may have different voltage curves and their specific energy may be in different voltages areas.
So lipos have energy in the higher voltage range and if you compare them to 18650 li-ions they may have their most energy in a lower area around 3,5-3,8v area
What effects does this have to parallell different performance cell?
I don't know more than I'm letting go of my setup of 18s 18650s and 2 s lipo and a 1slife4po. Not because of performance issues but I like to use a technology that is less risky. Also if noted I use a 1s of life4po which is kind of a safety cell as it will just "eat" over-voltage if charged to much for any reason. For my usage it's not needed but it adds a layer of security to my battery.
When paralleling two different battery packs of different types you may have one pack giving out 20% power and the other the rest, that is 80% when the whole pack is fully charged at 100%. However meanwhile and when it is being used this ratio may change as the packs charge each other to make the voltage even between the two paralleled packs. When you are reaching 0% SOC in totalt it may change as well and maybe so much that it's not useable. Or it will be useable. To start you need to follow and check as you go to as not anything bad is happening your batteries when they are being discharged or charged. Like that they don't get to hot to touch or similar.
Salestech in an ebike store
Without resorting to a dc-dc converter, you'll have to change the cell count to match the voltages. A 16s LiFePO4 will have a maximum charging voltage very close to a 14s Li-ion pack. As others have pointed out, they have different discharge curves, so there will be a tendency for one to do more of the work in the beginning and there will be some losses from charge shuttling between the packs if the load is not constant
You can't do that directly. What you can do:
1) Change the S count to match the operating voltages of each pack. For example, a 16s LiFePO4 might work OK with a 14s Li-ion as long as you matched them in voltage first. It won't work perfectly. You will almost certainly need to charge them separately.
2) Use a current limited buck to drop the 58 volts from the 16S Leaf pack to the 52 volts of the 16s LiFePO4 pack. That would allow you to run the Leaf pack almost flat, then (effectively) switch over to the LiFeP04. By adjusting the current limit you could play with how fast the Leaf pack discharges into the 'main' battery.
