Wanting to buy a 100 18650 batteries
coopz
Hi I’m looking for the best place to buy 18650 batteries to build my own pack.
Any links would be much appreciated
Cheers
Scott
Because you are in Australia, you have to check out your local australian suppliers. Korea and Japan are your nearest countries which have 18650 factories.
best way to use google in Oz:
https://www.google.fr/search?num=100&ei=vVruWpT8NMOS6ASuhaCYBg&q=18650+site%3Aau&oq=18650+site%3Aau&gs_l=psy-ab.3...13172.13938.0.14164.5.5.0.0.0.0.171.596.1j4.5.0....0...1.1.64.psy-ab..2.0.0....0.uIpMJWwLVi0
Oz 18650 topic:
https://www.ozbargain.com.au/node/324863
to ship from europe, you can check out the for sale zone of this forum. If you get from ali express, weigh the batteries and use the guarantees if necessary: https://fr.aliexpress.com/item/Useful-2-4-8-12-16-20PCS-3-7V-NCR-18650B-3400mAh-Rechargeable-Batteries-For-Panasonic/32833159302.html?spm=a2g0w.search0104.3.1.489415a8kbzhTk&ws_ab_test=searchweb0_0,searchweb201602_1_10152_10065_10151_10344_10068_10342_10325_10343_10546_10340_5722611_10548_10341_10698_10696_5722911_5722811_10084_5722711_10083_10618_10305_10304_10307_5711211_10059_308_100031_10103_10624_10623_10622_10621_10620_5711311_5722511,searchweb201603_32,ppcSwitch_4&algo_expid=0c9f82e9-2372-4fba-8ee2-3658503aa525-0&algo_pvid=0c9f82e9-2372-4fba-8ee2-3658503aa525&transAbTest=ae803_1&priceBeautifyAB=0
Thanks very much mate for the reply,I will check those links.
Cheers
Scott
How are you going to be able to spot-weld. Or solderingb or interconnections blocks together as a Lego type situation how many amps do you need from this pack at how many volts looking forwarddt to you build on this pad but what style.
I ordered my 18650’s through NKON.. and bought a spot welder to.. looking forward to building a few packs
I ordered cells from FEP - same place I get the pouches from. They were about AUD$6.30 each landed.
