I want remove old battery in case (Swollen battery) how to remove battery .help me
peleap 100 mW Joined Nov 27, 2016 Messages 49 Jun 12, 2018 #1 I want remove old battery in case (Swollen battery) how to remove battery .help me
K kdog 10 kW Joined Feb 2, 2014 Messages 715 Location hobart, tasmania Jun 12, 2018 #2 1x Wooden block same dimension as cell, 1x Hammer. Apply in usual fashion .
fechter Administrator Staff member Joined Dec 31, 2006 Messages 16,539 Location California Bay Area, USA Jun 12, 2018 #3 You might want to spray a little isopropyl alcohol along the edges first to loosen the hot melt glue and act as a lubricant while hammering.
flippy 1 MW Joined Aug 12, 2015 Messages 2,351 Jun 12, 2018 #4 kdog said: 1x Wooden block same dimension as cell, 1x Hammer. Apply in usual fashion . Click to expand... from bottom only to prevent poles from caving into the cells. apply repetitive tool impacts liberally.
H Hillhater 100 TW Joined Aug 3, 2010 Messages 13,074 Location Sydney ..(Hilly part !) .. Australia/ Down under ! Jun 13, 2018 #6 Make sure all cells are fully discharged (<3v) . Use the IP Alcohol as Fetcher said, between the casing and the cells. You will have to knock them all out as one piece as those cells are heavily glued and taped together in a block.
amberwolf Administrator Staff member Joined Aug 17, 2009 Messages 40,767 Location Phoenix, AZ, USA, Earth, Sol, Local Bubble, Orion Jun 13, 2018 #7 peleap said: Can we get a swollen battery? Click to expand... Why would you want to? You already have one in this thread.
