I posted this on reddit but i think I will get more responses here:
I am specing out my cells now. I am between a 20amp and 10amp discharge 18650 cell in a 14s4p pack. The 10amp discharge cells have a little more capacity though.
the 10 amp cells should give me 40amps at 52v of discharge available (not sure about burst rate though)
the kit that I am getting is a 1200w 48v motor. Theoretically, the amp draw should not go above 23 amps (52v at 1200 watts). I am not sure how this plays out for burst though. Will the speed controller prevent any draw above 23 amps or is it possible to get much stronger drains than that.
Should 40 amps of discharge be sufficient for this application with out risking damaging the battery?
