Hi, I am building a pack 4S9P and I would like to use a GX connector,
I saw GX12 connectors that can handle 5A at 220V or GX16 7A at 220V
Would a single pin of a GX 12 could handle 10A at 16V ? I guess yes if P=U.I then a single pin would support just 1/10 of its maximum at 10A and 16V right?
or should I use 4 pins of a GX12 and connect the + and - to 2 pins each to divide the amps going through each
or should I use a GX16 ?
Thanks!
Thanks!
