Icharger DUO 4010 smoke
BoomerChomsi   1 kW
Post by BoomerChomsi » Jun 21 2018 3:32pm
I have accidentally connected 72V to Icharger 4010...... :oops: :oops: :oops: (forgot to split pack when charging).
To bad for me, fets (IRFB3306G) are blown and a one smd diode.
I have searched many times for this type of diode ( marking on diode > MT 1423 ).
Well no luck for me....
Can anyone help me? Thank you very much!
Believe and Do
joffrey   1 µW
Re: Icharger DUO 4010 smoke
Post by joffrey » Jul 04 2018 6:44am
I just made the same mistake...
Diode D24-2 is blown.
Hopefully replacing the diode will fix it.
Did you find the component value?
Mart76   10 µW
10 µW
Post by Mart76 » Jul 22 2018 1:46pm
Hello fellow Junsi-DUO 4010 users.
After you replaced the FETs, normally the Diodes will test good. If not, post again.
Best not to unsolder the legs of the broken FETs. Cut the old ones just under the body and solder the new ones on the remaining legs. You will not be able to solder new legs into the board! unless you are very experienced and have very powerfull and good equipment.
Greetings,
Martin
Mart76   10 µW
10 µW
Post by Mart76 » Jul 22 2018 1:48pm
Greetings,
Martin
BoomerChomsi   1 kW
Post by BoomerChomsi » Nov 17 2018 5:58am
I was able to unsolder fets legs completely , yeah just use solder temperature at highest setting and biggest tip.
Too bad for me I have noticed fet driver is has been shaved , so looking for replacement is very....
I think this area is causing fet to blown every time, when it has been replaced....
Believe and Do
