want to build
- Joined
- May 18, 2018
- Messages
- 291
IHI everyone
did you have a good day?
I have a need for knoledge and clarity to choose a charger
I will put 48 v battery together and have to choose a bsm charger and buck converter 48 to 24v(ideally 25 26v)
I have sony vtc4 see spec at the end . i still have the choice to go for 12s or 13 s . probably 5p and and addon pack of 3more cell parallel. the wall plug is north american 110v.
I have read some stuff . I am still a noob
i will have a 48v batterie
here are some questions
1 why are sellers on alibaba asking how many AMP hour th battery have? i mean whether i have 13 s 5p or 13s 8p the charger should still work no?
2 i noticed that there are like 2 voltages on charger. like its name 48v for example and in the spec thy put higher voltage like fifty something...? what do i need to check and be aware of?
3 how to select the out put current of the current? I read on luna cycle that the have a kind of charger that charges at 3A and 5A you can chose. is this a necessity? cause they dont have 48v charger (they only have a mini). so i have to learn? what there is to learn to choose a charger. I already know that the more watt a charger gives the quicker the charge will be done . that is about it. i remember reading that charging a battery to quickly is not good.
Tx for helping me geting better
Charge your Sony VTC4 only on 18650 chargers. Smart chargers are highly recommended.
Specifications:
Rated capacity: 2100mAh (high drain)
Minimum capacity: 2000mAh
Initial discharging current: 15A
Maximum continuous charging current: 6.5A
Maximum continuous discharging current: 30A
Voltage: 3.8V
Nominal operating voltage: 3.2V
Maximum charge voltage: 4.2V
Discharge cut-off voltage: 2.5V
Dimensions: 65.0mm (L) x 18.2mm (D)
Specifications:
Voltage: 3.8V
