want to build
- Joined
- May 18, 2018
- Messages
- 291
Hi how are you doing,
Ihavea need for clarity and advices
Ihave 13s8p sony vtc4cells spec at bottom
i'm looking at a good bang for buck bms. i dont know really know what options can a bms have that are intersting to have.
i want a 60amp continus (in reality i will not always use 60amp but it is good to have de possibility and if possible as water proff as possible.
i plan to charge with a 5A 48v(54.6V) charger
is the following item compatible with may cells and battery? i ask it because a saw a very similar bms on which was stated nicd... :?
https://www.aliexpress.com/item/13S-60A-48V-Lithium-Battery-Protection-Board-BMS-Waterproof-18650-Lipo-Li-ion-cell-for-electric/32876215563.html?spm=2114.search0604.3.45.3c7e720flXF8Yl&ws_ab_test=searchweb0_0,searchweb201602_1_10152_10151_10065_10344_10068_10130_10342_10547_10343_5722611_10340_10548_10341_10696_5722911_5722811_10084_5722711_10083_10618_10139_10307_10059_306_100031_10103_10624_10623_10622_10621_10620_5722511,searchweb201603_12,ppcSwitch_5&algo_expid=9bac780b-e060-4a17-bfd3-2d122e1f250a-6&algo_pvid=9bac780b-e060-4a17-bfd3-2d122e1f250a&transAbTest=ae803_2&priceBeautifyAB=0
As you see, they give the choice of 60A common port Version : common port for charge/discharge60A VS separate port Version : separate port for charge/discharge. what sould i choose that is the difference , effects and consideration?
thx
vtc4 Specifications:
Rated capacity: 2100mAh (high drain)
Minimum capacity: 2000mAh
Initial discharging current: 15A
Maximum continuous charging current: 6.5A
Maximum continuous discharging current: 30A
Voltage: 3.8V
Nominal operating voltage: 3.2V
Maximum charge voltage: 4.2V
Discharge cut-off voltage: 2.5V
Dimensions: 65.0mm (L) x 18.2mm (D)
Note: Sony VTC4 IMR cells have a much lower internal resistance than regular 3.7V lithium ions. Voltage could go higher when charged on certain chargers such as the older versions of the WF-139 charger. Always check the voltage of your 18650 IMR battery after a full charge to make sure it is above 4.2V. You can use a multimeter to do this. Overcharging your Sony VTC4 above 4.25V may shorten the life cycle or even cause permanent damage to the product.
thx
Voltage: 3.8V
