Best new cells or comeing ? better than the 30Q 15amp cell or LGmj1 10amp cells
Gab
Is their anything newer or better than the 30Q 15amp cell or LGmj1 10amp cells
these cells are getting quite old and am wondering what better is comeing ? or are all the new cells 21700 format ?
What do you mean by saying "better"? The capacity? Max discharge current?
There are two 3600mAh/10A cells available now - LG M36 and Samsung 36G. I've got the M36 and i'm gonna get the 36G to test and compare them.
It seems that LG M36 cells are overrated which is pity, because LG cell usually can discharge rated capacity at nominal 0.2C discharge. I got few samples from NKON and the cells can do ca 3400 mAh only. It is slightly lower than LG MJ1 and that corresponds to the values measured by Lygte-info. I will start with cycle life tests next week.
I'm looking forward to see Samsung's 36G cells results. Thunderheart did you already order samples of 36G from QB?
i need a 15amp cell is their anything better than the 30q cell?
Sony Vtc6
