There's a lot of places I see outlets around here where there are vending machines or other things plugged in, and one open outlet. Since many of these machines have refrigeration units, whcih in this heat run a lot, even drawing 4-5A from such an outlet could pop the breaker.
Quite a few places seem to be capping off exterior outlets, or turning the outlets off.
Even restaurants and fast food places may have interior outlets turned off, so people don't plug in laptops/etc and sit there for long periods (some also have signage limiting the amount of time you're allowed to stay there, often 30 minutes or less). There's a couple of places I used to go to (after the housefire while I was at an apartment during the rebuild) specifically so I could use their free wifi to get on the forums, that have rows of outlets just for you to plug laptops/etc into---but they were all turned off, and they wouldn't turn them on, cuz they didn't want anyone hanging around (even if you kept buying more food/etc).
That said, you could get a programmable or adjustable charger, so you can run it at high current when needed, or low current when you don't think the outlet will support anything more, or when you just don't want to abuse the pack.
Meanwell HLG-xxx-xxA series LED PSUs (lots of threads about them) are adjustable via a screwdriver hole under a rubber cap, both for voltage and current. A pair of them in series would do 24s. So you could leave them set to low most of the time, and just adjust them to high when you know the outlet supports it and you *have* to charge quickly. (actually since they're in series you only need to adjust one of them; the other can be left at max current).
The Cycle Satiator from Grin tech is also adjustable and can have several presets to select from, but the high voltage version doesn't do high current, so you'd have to parallel more than one to do that; the meanwells are a much cheaper option in that case, if a bit more tedious to change on the fly.
