Son's concept
johnrc   1 µW
Son's concept
Post by johnrc » Aug 12 2018 8:58am
Hello,i’m newbie John from Greece
I start making a project for my son and i need your thoughts…the project is a little bit different from the forum vehicles but e-system is allmost same
Watching this instructable video https://www.google.gr/amp/www.instructa ... _page=true 10
i decided to make a small sea scooter board,on this board: https://www.gidivestore.com/eu/en/buoys ... board.html 8
but i dont know many things so i need your help.
I bought from their suggestions the following:
1.DT700 brushless motors: 2 pcs (i will run them parallel always at 30A,the easy way is to stuck the potensiometer to 30 A and use an run -off switch for the hole system but i dont know where to connect…Am i correct or …
Kort nozzle for DT700: 2 pcs
ESC speed controller 40A with BEC(i think from the price is garbadge…)
https://m.ebay.com/itm/For-RC-Helicopte ... 7784451019 1
https://m.ebay.com/itm/RC-SERVO-TESTER- ... 1217347012 1
10K Linear Slide Slider Electronic Potentiometer Module Dual Output Arduino
Sony Konion US18650VTC6 3120mAh - 30A.I think that 3s10p is a good choice for about an hour runtime,
My questions:
1.do i need fuse?what A and where to place it?
2.which waterproof on -off switch and where to connect?
3.is it safe to use those servo tester, potensiometer and esc?or sth else?
4. What bms?with or without ballance etc.
5.all in a ip67 box or separate the li-ion pack from the esc?
Thanks in advance
