Mikebike
Have a lifep04 pouch battery made of 24 cells for my cargo bike I bought used off the forum a while back. 12s2p
Charger died and so I wanted to learn about the inner workings of this beast and I took the cover off.
Appears that the BMS is not wired right? I am learning about this and I also want to add a cell logger to put on here so I can see the actual voltages. Shouldnt the first small sense wire b- be on the negative of the battery, then the first b+ be on the + of the first cell, then repeat b2, b3, etc. all the way up to b11, then the last b+ on the final + battery output?
Seems like whomever wired this didnt put the sense wires on the BMS properly? Never worked on a battery like this before so any help is appreciated.
