Analysis of my Main Battery Pack
markz
100 TW
Canada and the USA
Used to get quite a bit of distance, current formation was getting 22km which was alright.
10S10P 36V and 16Ah(new) cells are Sony 18650-V which are 1.6Ah.
575Wh should net me 26km at 22Wh/km when new, 375lbs, never pedal :oops:
Pack is not new but is a 2 year old pack. Used every day! Charged multiple times a day and been a real champ for me.
The 3.41 and 3.62 voltages were dragging the entire pack down. Distances were pathetic!
Understandably so!
Perhaps this go around, I will wire in balance leads, we will see!
I will balance charge strings B, C, D to exact voltages and pair them together into its own pack.
Moistness does not feel that bad inside the pack, on the wood or on the tabs.
It was taped up with Gorilla tape and used 1/8" mdf board.
The came too loose too easily is just a statement of fact that when I was opening up the pack and peeling back the Gorilla tape, taking the 1/8" mdf wood off, a series connection can loose too easily from a ~2" fall onto a glass topped desk, my office desk.
Here are the measured voltages.
Can you post a picture of the pack?
Having 5 parallel strings of 10s is an unusual pack configuration. Normally the parallel connections are made at every series cell, which forces the cells in each parallel group to be balanced.
Were the cells ever balanced during the 2 years?
No BMS, not even balance leads to use 80W balance charger, However I do balance them when I get them, let sit, make note of chages
I am just lazy is all, I received 5S2P packs, I open them up, discard pcb and housing
My phone is somewhere around, if I had it here, I'd snap some pics, but I will explain it all better for you
The battery pack has been through a handful of different changes, from 48V 13S, 36V 10S, different Ah combo's.
The battery "bricks" as I like to call them are 5S2P, arranged in a desired format, as discussed^^^^
Some end up not living due to situations like we have here.
So healthy sections are taken out and reused.
While unhealthy sections are "helped along" to use as a bicycle light, stored or responsibly discarded (fire station)
BTW I did edit my previous post, new picture of spreadsheet.
All in all its a pretty easy fix.
I should open it and inspect more frequently.
I should solder in balance leads to each 2P, bulk charge to 4.00V then balance charge to 4.20V. Saves time especially when all I got are them cheesy ass 80W rc chargers, wishing for an iCharger, Satiator, and a Grinspector.
I should use the mini voltage meters to keep a closer eye on things.
For a clearer image of the situation:
What I have now is five "strings" of 10S2P on pieces of computer paper with their voltages written down.
They are 5S2P "bricks" with tab welds on them. I then used solid copper wire to solder a series connection.
Visualize this:
I have one "string" that has two 5S2P soldered in series. 5S2P + 5S2P = 10S2P
I have another one that is the same as above. 5S2P + 5S2P = 10S2P
Then I have 4S2P + 4S2P + 2S2P and 5S2P + 4S2P + 1S2P and 5S2P + 3S2P + 2S2P
As seen in the spreadsheet.
Obviously I tie each positive and negative together from the ends of each 10S2P, to make a complete pack.
So yes maybe that is strange, not having a fully parallel wire across every 18650.
So the 5S2P can be sectioned out and made into various states from 1S2P, to 2S2P, to 3S2P, to 4S2P.
This is what I did originally, I charged each 5S2P "brick" to 3.75V and stored them in the office closet and I let sit for months and months. Periodically I would measure the voltages of everything, and see where the changes were happening. Overall everything was very good, a few bricks had to be split into smaller sections.
Hope that helps!
Got a plan layed out, easy fix. Nothing major.
One thing I forgot to mention in the "I should", yes yes yes a BMS I know I know.
OK comments please, I am ready for it!
Be easy on me.
Main pack, picture shown below.
Previous to this work...
10S6P that I was getting pathetic mileage from. Normally 15km, but there was some moistness to the pack, very very little, somehow it got through the layers of duct tape, and the cardboard. It held together in perfect condition except there was like very little dampness to it, undetectable really. Opened it up and it looked good, except moistness. Hair dryer set to medium temperature setting, and literally only had it on for no more then 30 minutes, both sides. Slapped on 1/8" mdf wood, grey duct tape, then black gorilla tape so no one will know what it is ;) Test run reveals, 10km with power still left. Dunno about any of you, low juice left its noticeable when and where I will run out. Pack was located on the rear rat trap rack. Thankfully I have installed full mudguards just yesterday.
So, it maybe awhile or not before I get this Main Battery Pack back together. I say "or not" because I need to do business taxes this weekend, have to clear up the desk.
It looks like you could gain a good amount of capacity by balancing the cells. You could do individual bricks with a RC balance charger.
