Just tested a 10 month old pack of a customer of mine and the pack started sagging really bad lately, it was about 5V sag under 110A load when it was healthy and about a month ago the sag started increasing to even 15-20V.
I tested the sag while bypassing the BMS and it was the same.
The pack never heated up, was always room temp, it looks physically brand new.
The pack was built with original fresh stock (tested the codes on the internet) Samsung 25R cells.
It's a 72V 20Ah built with 0.15mm 8mm wide pure nickel.
The first and last cell rows have each cell connect to a copper busbar for even current distribution.
Pack is perfectly balanced.
The guy was riding it everyday and 110A is usually bursts, even if on the highway on full throttle it never pulls constant 110A.
Even if it was constant 110A, thats 13.75A (burst) from each row of cells which is below the 20A rating of those cells.
I'm clueless, could it be that this is what I should expect as the longevity of packs under that amount of stress on a daily basis for 10 month?
