Hello EndlessSphere,
I'm building a BMS to monitor a ~400V battery pack for an electric motorcycle, which would be broken into 4 packs of ~100V each, with about 20-24S in each of the 4 packs. At the moment I'm considering using LTC6802-2 cell monitoring chips and using 2 on each pack to monitor each pack independently. Ryan Biffard from Zero recommended using the Texas Instruments BQ76PL455A-Q1 stackable cell monitoring chips, with again using about 2 on each pack. I was planning to program them to run some switching relays to convert the 4, 100V packs from a 400V series mode to a 100V parallel.
I wanted to know what are your thoughts on each or what other good options that you have tried or tested? Or perhaps any critique of those chips? Of if you could link me to any threads for building a custom BMS, as my searches have come up empty.
Cheers,
Cheers,
