36V Battery bms question
api   1 µW
Post by api » Oct 13 2018 9:42pm
i got 40 3.7 cells 2130mah and i am going to make a 36v battery with 8.5ah can i use a 10s 10a bms or is there 8.5a bms specifcly?
LuboN   10 mW
Re: 36V Battery bms question
Post by LuboN » Oct 26 2018 4:21pm
8,5Ah is capacity. BMS is rated for current. Chose the BMS according to how many amps are You going to draw from Your battery.
Matador   10 kW
Post by Matador » Oct 26 2018 11:09pm
Aka check the vaue of your controller (Max amp draw), multiply by 1.25 or 1.5 and chose that amp value for BMS
