I bought this battery pack for my hub motor ebike. I am guessing that the red and black bare wires will connect to the
controller on the ebike. What is the single (black plug) wire for?? The 36v charger?
Because that particular BMS was designed with a separate Charge port.
If you decide to charge from the thick wires it will not cut the charge current if a cell is out of balance.
Which will cause rapid cell degradation and or flames.
You can get them with the same charge and discharge ports if you want.
You could also replace it with a different BMS.
But unless you know what you are doing I recommend you use it as it is.
