I want to assemble a nice ebike pack using 18650 cells. It will be around 2 kwh.
I'm considering 72v made with 1s 10p modules and doing the series connection with Anderson's or RC bullet connectors.
I want to go big for range and also so that I can charge to 3.8-3.9v for better cycle life and nice easy discharge rates.
If breaking it up in to 1s packs and all of the connectors are going to cause problems, let me know. I want to go modular so it's easier to repair individual cells or fix ballance issues if I have them. It would give me nice heat shrunk triangles that I can stack and less worry of shearing off spot welds.
Thanks to anyone that can help with advice or a welder.
I am about to order my cells and nickel strip so a welding day sometime in December will be ideal.
