And actually there is multiple goals to achieve when building this.
1. It should be lighter than my current ones.
2. I want to use this for my two controller+motor 1/4 mile test insted of two lifepo4 packs.
3. Not needing to cool pack between races
Right now plan is to get 24pcs of Turnigy Heavy Duty 5Ah 7s 60C bricks. And use them in configuration 4s6p, so total of 30Ah and 28s. I think these will provide me average 200A in 8 minutes with max 640A easy. And also like 1300A for 10 seconds when using two motors.
Bought one for testing and measurements, its 50mm x 60mm wide and 160mm height with wires. I would prefer that it had 8AWG wires instead of 10AWG ones. Case would be made of 3mm hobby plane plywood so that it has 24 slots for bricks 4 in width and 6 in length. And there will be additional 50mm in the side for wires and bms and fuse and dc/dc and olimex with lcd.
So total size will be like 268mm width and 381mm length and 180mm in height.
Weight will be like this, this is my estimate.
1. 24 bricks 0,91kg a pcs will be 21,84kg
2. harnesses with 20cm 8AWG cable to each brick and xt90 and crimps and lugs will be around 2,37kg
3. two anderson 350 (one for each controller) will be 0,5kg
4. 3pcs of zeva bms + olimex + fuse + lcd + dc/dc is aprox 0,7kg
5. balance cable harnesses around 0,5kg
6. plywood will be around 3kg
so together around 28,91kg, lets round it to 30kg
will add more info and drawings when they are ready.
