Reco's requested, requirements in priority order, fantasy "ideally"s at the bottom.
Top quality regulated stable voltage DC output from possibly dirty mains input,
Capable of running safely in an off-grid no-true-ground context like marine- or wheeled-vehicle-based generators. Ground may simply not be available, even a 2m rod into dry desert earth is not great. Middle of the Great Lakes dunno, not a sparkie, would rather a design assuming no true Earthing available.
Safety features, to be operated by noob idjits (even more so than me), so use of ground leakage circuit breakers, ELCB's, or residual current devices, RCD's, etc?
Reliability, long-term heavy use in the field.
2200W continuous output, or close anyway.
Between 35V minimum and max is 49V
Sometimes only 10A USA 110V available, sometimes 220/240 up to 3-phase industrial whatever that means. Ideally worldwide compatible, include Euro, S.America, Japan.
Really ideally could power from two separate gennies or 10A 110 circuits. Willing to go to two separate 1100+W PSUs paralleled or in series to get this?
The output could be 24V nominal, if series'd able to get to 48V. Apparently only 2 in series is the limit, not true for paralleling?
Or ideally just one big unit can be fed from 2 separate AC sources, which can get to 55.2V, but is adjustable down to get to 49V, and/or even 13.8 / 27.6 as well (4s/8s/16s LFP)
But willing to use DC-DC buck boost conversion to get to those low ones if necessary.
Compact, cool and quiet as possible would be nice.
As would cheap!
Have so far come across:
ELTEK Flatpack2 (some only 2000W?)
Cherokee CAR2548
ES120
Mean Well RSPs
Eaton APR
As would cheap!
Cherokee CAR2548
ES120
Mean Well RSPs
Eaton APR
