BMS for charging only.
deronmoped   10 kW
Post by deronmoped » Feb 11 2019 2:18am
I have a RC LiPo pack that I want to make charging easier. The way I have been charging it now, is alternating between a bulk charger and charging the cells individually with a balance charger. I would like to use the bulk charger most of the time, but cells go out of balance very quickly. It's a pain charging, so for that reason, it limits my use of the bike. The pack is 10S2P. The question is, can I install a BMS to just balance the pack? I would not be using the output function or discharge limit function. I would still be using my existing ESC for output to the motor. I have a low voltage alarm.
Sunder   100 MW
Re: BMS for charging only.
Post by Sunder » Feb 11 2019 4:43am
Yes. This is fine. As long as you are leaving the pack on the charger after it finishes to balance regularly, the cells should not fall out of balance so far that its an issue.
Still check from time to time in case you have a faulty cell though.
eBike: Q100H on 16S with Phaserunner FOC Controller
eMotorscooter: Vectrix VX-1 on 36S
eCar: Mitsubishi Outlander PHEV... Waiting for warranty to expire
eHouse: 5.5kw On-grid solar with battery backup coming soon!
After 5 builds, the best advice I can give, is start with high quality products. I prefer http://www.ebikes.ca
deronmoped   10 kW
Post by deronmoped » Feb 12 2019 10:55am
OK, I'm going to give it a try. I see there is a ton of BMS boards out there, is there a board that is preferred? Or is there a go to dealer that backs up their product?
999zip999   100 GW
Post by 999zip999 » Feb 12 2019 2:00pm
What cells ? Fo you hammer them ? How old ?
kcuf   100 W
Post by kcuf » Feb 12 2019 3:22pm
expensive bms may see some support
too many variables wiring bms to pack to expect much
i do this find bms on ebay
5-15a bms cheap and good enough for charge only
balancing will be slow 40ma 80ma bleed current
takes long time if pack badly out
wired correctly will protect charging cells
In 2013 an ad appears on Russia social networks: Интернет-операторы хотели! Работа в шикарном офисе в Ольгино !!!, зарплата 25960 рублей в месяц
