PURE Nickel strip
PURE Nickel strip
Where to buy pure nickel strip?
I tried 2 aliexpress stores and 3-4 Serbian local stores and no luck.
Is there any place where i can buy PURE nickel?
Thanks!
Thanks!
Re: PURE Nickel strip
I bought this one twice, it's legit:
https://www.aliexpress.com/item/Pure-Ni ... 10924.html
Scratched and left it in saltwater over night, no rust.
Also soft and doesn't break after bending it often.
The seller also has other sizes.
Like wise did the same to this H strip from Annbattery, have bought 3 times now.
https://www.aliexpress.com/item/18650-b ... 4c4dbujdYt
Waiting for this to arrive so I can test it.
https://www.aliexpress.com/item/5-m-rol ... 4c4dt7xCRK
- amberwolf 100 GW
- Location: Phoenix, AZ, USA, Earth, Sol, Local Bubble, Orion Arm, Milky Way, Local Group
- Contact:
Perhaps some of these will help?
search.php?keywords=pure+nickel+strip&t ... mit=Search
If you found this advice helpful, supporting contributions are accepted here.
"if it ain't broke, improve it till it is"----Dog-Hauler Cargo eTrike SB Cruiser----The HI-Lebowski: a Lebowski SMD brain running a zombified Honda IMA Inverter: a HOW-TO guide----Cargo eBike CrazyBike2----General Blog
Yeah i used search option but those threads are old and some links are dead. I wanted to have some fresh informations.amberwolf wrote: ↑Feb 19 2019 11:58pmPerhaps some of these will help?
I have tested this one by deep grinding the surface and a saline solution, no rust deposits or discolouring to Nickel or solution.
I ordered from here https://annpower.aliexpress.com/store/6 ... 12f7q56eiF
Lets hope this is pure.
I have not had any issues with purity from Ann.
holy shait, tha stuff is expensive.BotoXbz wrote: ↑Feb 19 2019 12:56pmI bought this one twice, it's legit:
just order from here, you can buy by the kilo.
https://www.aliexpress.com/item/1kg-rol ... 74543.html
Lithium beats liquid dinosaurs.
It's cheaper for me to buy that than paying import tax and processing fees in EU on the bigger one...flippy wrote: ↑Feb 25 2019 1:09amholy shait, tha stuff is expensive.BotoXbz wrote: ↑Feb 19 2019 12:56pmI bought this one twice, it's legit:
never had to pay import tax with this one, they mark it with a value of 10 bucks or something like that. and its just a roll of metal, customs dont care about that.
Go cheap like big battery rebuild company do en get this crap
this is a real joke and i see this al the time
I tried to find pure nickel in Serbia - no luck. 3 "serious companies" who works with batteries (cells reparation and similar) have "nickel" in their shops. All 3 nickel plated steel. Total amaterism!
thats not so bad, i got way worse batteries i needed to rebuild in the past years due to crappy stuff like this
some even got their entire strips rusted away due to water ingress.
for battery builders that shit is inexcusable.
I recieved this nickel strip and its pure.krlenjuska wrote: ↑Feb 24 2019 6:31amI ordered from here https://annpower.aliexpress.com/store/6 ... 12f7q56eiF
I buy from these guys too and can recommend. Also they have it in pretty much whatever thickness you want.krlenjuska wrote: ↑Apr 20 2019 9:49amI recieved this nickel strip and its pure.krlenjuska wrote: ↑Feb 24 2019 6:31amI ordered from here https://annpower.aliexpress.com/store/6 ... 12f7q56eiF
