jangles
1 W
DHgate has this listed on a battery pack I am interested in . Does any of this make sense ? Has anyone ever bought from them ? It is in a Frog battery Pack that mounts on the seat down tube .
Specifications of electric bicycle battery:
Nominal Tension: 48 V
Nominal Capacity: 20Ah
Compound type: 13 Series 8 Paralles 13S8P
Cells: Li ion 18650 3.7 V power cells
BMS: 30 Amp continuous 70 ± 10Amp maximum
Motor Adjustment: 48 V 500W 750 W 1000 W
Charge current: 2-5A
Load cut voltage: 54.6 V
Discharge cutting voltage: 36.4V
Discharge temperature: -20 to 65 ° C
Charge Temperature: 0 to 45 ° C
Dimensions: 260*160*120mm
Battery weight: 8 kg
Life Cycle: 80% capacity for 1000 cycles
