Hello guys,
I'm working on a new ebike build EEB frame, QS205, 72200 mobipus controller.
I currently have this battery pack for the build :
- ANT BMS
- 20s5p
- 21700 format
- 12A burst per cell
- 3800mah per cell
- 3.65V nominal
- 1.387KW total
- 1C max charging current
I would like to add another one in parallel with 18650 :
- ANT BMS
- 20s6p
- 18650 format
- 3500mah per cell
- 10A burst per cell
- 3.65V nominal
- 1.533KW total
My worries are the following :
- As the 2 battery packs does not have the same amount of power, these two will be unbalanced. When this will arrive, the big one will drive current into the small one to refill it. My fear is that the current flow may be too strong and will be far superior as the 1C max charging current of the batteries.
Are these worries are founded ?
How can I limit the max charging current between the two ? DC-DC converter with max-current limiting ?
Thanks for your help guys!
Cheers
- ANT BMS
- 20s5p
- 21700 format
- 3800mah per cell
- 3.65V nominal
- 1.387KW total
- ANT BMS
- 20s6p
- 18650 format
- 3500mah per cell
- 3.65V nominal
- 1.533KW total
Cheers
