Adding CA Connector Infineon 18 FET Controller
Archive of useful information. This is not a discussion area.
rkosiorek   1 MW
Post by rkosiorek » Mar 22 2010 8:54pm
Lyen wrote:Hello Silver! Sorry to leave you in the dark for over 120 hours. I've been busy shipping things to many ES members here. But there is no excuse for me. I have made a thread here on how to wire it properly for you below so other members can benefit from it as well. Please let me know if you have any other questions. Thanks!
So here we go:
1. Determine the pin number & colors to the connector:
2. Add a diode (1N4001) to pin number 6 (The negative of the diode goes towards the wire. Look at the picture carefully. Also, add a little PVC head shrink heat tube is ideal not not really needed):
3. Solder a diode to the wire (Confirm the polarity):
4. Add heat shrink tube:
5. Short a resistor on R36:
6. Solder in the blue wire with diode to the SLA pad:
To be continue...
DISCLAIMER:
We will not be responsible for damage to equipment, your ego, blown parts, county wide power outages, spontaneously generated mini (or larger) black holes, planetary disruptions, or personal injury that may result from the use of this material.
- Samuel M. Goldwasser -
rkosiorek   1 MW
Re: Adding CA Connector Infineon 18 FET Controller
Post by rkosiorek » Mar 22 2010 8:55pm
Lyen wrote:7. Solder pin #1 to VK2+ and pin #4 to the shunt location below:
8. Pin #2 to GND-8 (next to XC -)
9. Pin #3 to GND-8 (between pad P3 & XC)
10. Pin#5 to HE below:
Let me know if you have more questions. Thanks! :)
DISCLAIMER:
rkosiorek   1 MW
Post by rkosiorek » Mar 22 2010 8:56pm
SilverSurfer wrote:Bro, I think your note number 9 should read pin #3. Or you need to list pin 3's location if its not gnd 8.
9. Pin #2 to GND-8 (between pad P3 & XC)
DISCLAIMER:
rkosiorek   1 MW
Post by rkosiorek » Mar 22 2010 8:57pm
Lyen wrote:Oops! Sorry! I have updated with the correct info. :)
DISCLAIMER:
rkosiorek   1 MW
Post by rkosiorek » Mar 22 2010 8:58pm
Mike1 wrote:Pin 2 should really be connected close the the bottom of the shunt. I connect pin 3 there also.
DISCLAIMER:
rkosiorek   1 MW
Post by rkosiorek » Mar 22 2010 8:59pm
I believe you are correct as well Mike! I however do not see the differences in terms of accuracy. So this is just a personal preference for now until someone has hard evidence. Thanks! :)
DISCLAIMER:
rkosiorek   1 MW
Post by rkosiorek » Mar 22 2010 9:03pm
these instructions were originally posted as Adding CA Connector for SilverSurfer's 18 FET Controller
http://www.endless-sphere.com/forums/vi ... =2&t=17022
thanks Lyen for the excellent directions
rick
DISCLAIMER:
