How to install 12 gauge spokes to conventional ebike rim
Archive of useful information. This is not a discussion area.
Doctorbass   100 GW
Post by Doctorbass » Sep 23 2011 8:44pm
I made a quick video to show you a trick to remove the eyeslet of conventional rim to be able to fit the 12 gauge nipples
As well.. i'll add a washer between the nipple and the rim to extand the surface area and not stress too much the border of the aluminum holes
That idea become 100% bulletproof by completing it with that following nipple and eyeslet upgrade:
I must add that the main idea is this:
- to be able to fit 12 gauge spokes to normal eyeslet rim
- to gave stronger wheel assembly
- to use a known mecanical principle to distribute the force with uniformity around a hole ( spherical washer technique)
- Having a larger surface in the rim than a common eyeslet offer where the pressure is applied by the nipple.
- Be able to NOT bend the spokes and have a stronger wheel
- Having better quality spokes and nipples with HOLMES HOBBIES LLC stuff than the past NewsonSportec one wich had a REALLY bad QC.. ( half the nipples was unusable )
The spherical washer is a known device in mecanical ingeneering that allow to apply a force that is applied in a specific direction and to preserve the uniformity of the pressure applied on the parts.
12g spokes with better nipple and eyeslet.JPG (64.98 KiB) Viewed 3425 times
CURRENT PROJECT: 2WD duo MXUS/Max-E ebike 32kW
http://endless-sphere.com/forums/viewto ... =3&t=65764
-Fastest speed record 117 km/h on flat
-Fastest 1/4 mile@ 114km/h on flat and 16.316 sec
113kmh Gianthttp://www.evalbum.com/3406
Mongoosehttp://www.evalbum.com/1947
YOUTUBE---https://m.youtube.com/user/Doctorbasss
I speak FRENCH and english
