Crystalyte Controllers - Repair and Modification information
Archive of useful information. This is not a discussion area.
calinb   100 W
Re: Crystalyte Controllers - Repair and Modification information
Post by calinb » Jan 22 2008 9:13pm
After I switched from SLAs to a Yesa pack, my low voltage light in my throttle became useless because the Yesa pack voltage never goes low enough to trip it. While I'm saving my nickels for a Cycle Analyst, is there a way to modify my controller to adjust the low voltage warning?
Thanks,
-Cal
fechter   100 GW
Post by fechter » Jan 22 2008 10:18pm
Yes. If you look toward the bottom of page 1 of this thread, you'll see the location of the low voltage cutout resistor. To get a higher voltage, you need a higher value resistor. Unfortunately, I never seemed to get that part of the circuit properly mapped out and there seems to be some variation between examples, so you may need figure out the right value.
If you take apart your controller and look closely at the resistors, you may be able to read off the numbers. From there we can make an educated guess as to the new value.
You could also replace the fixed resistor with a small trimmer pot to make the LVC adjustable. You will need to figure out a way to simulate the cutout voltage to test the circuit as well. A bench power supply is the best, but who has one of those? You could temporarily put a battery in series with the main pack *backward* to lower the voltage by a given amount. Even a small battery will be enough to test the LVC.
calinb   100 W
Post by calinb » Jan 23 2008 3:39pm
fechter wrote:Yes. If you look toward the bottom of page 1 of this thread, you'll see the location of the low voltage cutout resistor. To get a higher voltage, you need a higher value resistor.
Cool! Thanks, fechter! I'll report what I find. It'll be my next project--right after I cut/thread 36 Sapim 12 ga spokes and lace up my new Salsa Gordo rim! :) My original rim supplied with my 5304 is cracking.
-Cal
Drunkskunk   100 GW
Post by Drunkskunk » Jan 24 2008 3:20pm
The voltage regulater on the 12 volt side, just how much power can it put out extra? Could it be used as aDC sorce for other things on the bike?
fechter   100 GW
Post by fechter » Jan 26 2008 11:30am
Yes, you could power something off that. The pass transistor is good for a few amps and the controller is only using about 0.1 amps. It is a linear regulator, so it will waste most of the power and get pretty hot. If you take the (pack voltage-12v) x current= heat dissipated, you can get an idea of how hot your controller will get.
I'd recommend one of those switching power supplies with the wide range input or a dc-dc converter. Much less heat.
Drunkskunk   100 GW
Post by Drunkskunk » Jan 26 2008 2:31pm
Thanks! good to know. I haven't found a switching DC-DC that would do up to 85 volts,function as low as 29 volts, and have an output around an amp. I figure I would have the controller feed an accesory battery, and run everything off that. Full current will only be needed a few seconds at a time.
solarbbq2003   10 kW
Post by solarbbq2003 » Feb 11 2008 5:44am
anyone thought of using transient voltage suppressors to protect fets from voltage spikes, was some discussion on it for dual speed motors, but might make controllers less prone to fet damage
fechter   100 GW
Post by fechter » Feb 11 2008 10:07am
I'm not sure if they make them in the right voltage?
Anyway, it's better if your main capacitors are good enough that you don't need them. The energy can be recovered instead of dissipated.
You could get some benefit by adding super low ESR capacitors across the existing ones. Something like multilayer ceramic or polyester ones, less than 1uf. These can take up the very fast spikes better than the aluminum cans.
solarbbq2003   10 kW
Post by solarbbq2003 » Feb 12 2008 1:09am
thats very interesting, so without removing the old caps you could add the 1uf caps?
so the function of the three caps on the fets is to dissipate the voltage spikes?? I never realised that was wondering what they were for!!!!
fechter   100 GW
Post by fechter » Feb 12 2008 9:57am
The main capacitors have to shuttle huge amounts of current back and forth. If they are undersized, they will heat up and sometimes explode. The aluminum electrolytics are pretty good at carrying the bulk of the charge, but they are not really good at very high frequencies.
Without the capacitors, the voltage spikes from the PWM switching would most likely destroy the FETs immediately. The batteries behave sort of like capacitors also, but their effective series resistance would be very high at the switching frequency, partly due to the inductance and resistance of the battery wiring.
I've had a couple of controllers where the main cap blew first, immediately followed by a FET failure.
Multiple smaller caps work better than one big one. More lead wires make for less resistance.
nemo   10 W
Post by nemo » Feb 12 2008 12:20pm
I alway like to read this part of the forum, thanks to all of you!
Last time you helped me with recognizing zenner diode 13V. Does any of you have a layout of other diodes on the board? I can provide the quality photos. I don't have the original controller any more so I'm unable to confirm what is zenner and what is only a regular diode. Most of them are in smd. I think those close to mosfets are also zenners. My cloned controller worked on lower voltage just fine but then one day blew and I need to get to the bottom of the problem.(building another 3!) That 13V zenner will definitely help. I didn't even use zenners close to mosfets and later on read somewhere in datasheet that zenners on the gate should protect the gate and are readily used there.As well as small 5-10 ohm resistors.(they protect the driver chip in case of the failure of the fets)
So if you have an idea what diodes are where I'll provide the photos. I'm still planning on drawing the schematics for all but recently I'm too busy with other projects. Also I'm not really sure that there really is interest for somebody to clone the controllers as I did. If I'm wrong let me know. (this may speed the schematics drawing)
fechter   100 GW
Post by fechter » Feb 12 2008 3:08pm
Sure, post a pic. Most of the other diodes are just regular diodes. The larger ones are used in the driver bootstrap circuit. As I recall, the smaller ones are in parallel with a resistor to make the FETs turn off faster than they turn on.
Ah, here it is:
Brushless Controller Output stage.jpg (30.79 KiB) Viewed 3893 times
nemo   10 W
Post by nemo » Feb 12 2008 4:09pm
I've located some pictures from my pc of the original board.
Apart from bigger diodes that I can read and 1 smaller next to a big resistor that is 13V 1.3W zenner. There are 6 smd diodes (smd 4148?)paralel to 100ohm resistors going to 2n5551 as on your drawing. Then 1smd on the picture(unknown) and from the other side one smd called D4(unknown). All other parts I know. Thanks you!
diode 1.JPG (72.52 KiB) Viewed 3772 times
fechter   100 GW
Post by fechter » Feb 12 2008 4:25pm
I can't get to the one on the bottom easily since the heat sink is back on.
The one on top measures like a regular diode. I'd give you 90% odds the one on the bottom is the same. Something with a 50v rating should be fine.
nemo   10 W
Post by nemo » Feb 12 2008 6:49pm
Thank You, I'll try to confirm this from the schematic when I finish it. Nemo
momo   10 W
Post by momo » Feb 24 2008 9:06pm
I'm wondering if anyone got their hands on the complete schematic for the controller?
rkosiorek   1 MW
V1 and V2 Low Voltage Regulators -Crystalyte Controllers
Post by rkosiorek » Feb 28 2008 10:37am
here are the circuits for the 15V regulators used in the Crystalyte controllers. first the one used in the original analog controller.
Crystalyte Analog Controller 15V regulator
15V REGULATOR.jpg (18.82 KiB) Viewed 3702 times
and now the switching regulator used in the newer V2 controller
Crystalyte V2 Digital Controller 15V Switching regulator
Low Voltage Switching Supply.jpg (36.2 KiB) Viewed 3705 times
hope this helps.
rick
15V REGULATOR.pdf
(45.53 KiB) Downloaded 203 times
LOW VOLTAGE SWITCHING SUPPLY.pdf
Crystalyte V2 Digital Controller 1 5V Switching regulator
(16.2 KiB) Downloaded 178 times
DISCLAIMER:
We will not be responsible for damage to equipment, your ego, blown parts, county wide power outages, spontaneously generated mini (or larger) black holes, planetary disruptions, or personal injury that may result from the use of this material.
- Samuel M. Goldwasser -
giveahoot   100 W
Post by giveahoot » Mar 04 2008 2:17pm
Thanks to fechter for this great thread, and for so generously sharing information. I've learned so much from all your knowledge this past year. It makes one appreciate the limitless possibilities of this hobby, with a better realized ability to tackle them.
bobmcree   10 kW
Post by bobmcree » Mar 04 2008 2:53pm
D4 is a regular diode like a 1N914 or 1N4148.
I do not approve of this group any longer and regret what it has become. I could once share ideas here freely that is no longer possible.
ngocthach1130   1 kW
Post by ngocthach1130 » Mar 15 2008 4:16am
Hmm today i decided to do some wire maintenance on my bike when i decided to mod the controller while i have it disassemble anyway. I notice the wires on the new crystalyte 72v 35A controller is puny. They're like 14guage wires. I think i'll up them to 12 or 10. As people have stated these are populated with IRF4310 so i'm going to replace them with IRF4110. Someone asked this before about this controller having 6 Mosfet even though it have 12 slots. I did a quick look and i THINK there is gate resistor connection already provided for the unpopulated spot. Anyone have different opinion? Do you think i'll gain any any benefit to adding 6 more? I need to know since i have exactly 6 IRF4110 left from other mod and i'm thinking of ordering more. Don't want to waste time and money is it won't make a diff. Thanks ahead for any reply. BTW it's the white PCB version.
bobmcree   10 kW
Post by bobmcree » Mar 15 2008 5:08am
ngocthach1130 wrote:Hmm today i decided to do some wire maintenance on my bike when i decided to mod the controller while i have it disassemble anyway. I notice the wires on the new crystalyte 72v 35A controller is puny. They're like 14guage wires. I think i'll up them to 12 or 10. As people have stated these are populated with IRF4310 so i'm going to replace them with IRF4110. Someone asked this before about this controller having 6 Mosfet even though it have 12 slots. I did a quick look and i THINK there is gate resistor connection already provided for the unpopulated spot. Anyone have different opinion? Do you think i'll gain any any benefit to adding 6 more? I need to know since i have exactly 6 IRF4110 left from other mod and i'm thinking of ordering more. Don't want to waste time and money is it won't make a diff. Thanks ahead for any reply. BTW it's the white PCB version.
you are certainly better off with twice as many fets, whether they are 4310 or 4110. I have not seen the new controller yet, but i have a couple coming next week.
if you measure with your meter from the empty location's gate pin to the gate of the populated location you should see 20 ohms if there are 2 10 ohm gate resistors installed. i would not recommend mixing the 4310 and 4110, and the 4310 has a higher Miller charge than the 4110 so 2 4310's would need more drive current than 2 4110's, but if they are using the same boost circuit for the high side fets as the older controllers it should be fine with either part. If you are not running at over 50A you might keep the 4310s and just add 6 more of them. With 12 4110's i have quite a few controllers running around now set at up to 85A.
ngocthach1130   1 kW
Post by ngocthach1130 » Mar 15 2008 3:16pm
It's too late anyway. I already clipped off and desoldered the 4310. I was going to add the 4110 anyway. Just a decision of adding 6 or 12. I think the lower resistance of the 4110 is better since I'll be changing the battery wire and the motor wire to larger 10guage wires. This might result in higher potential current traveling through. At the same time I would probably use the same controller for 99v once in a while. So the robustness of the 4110 will help. This will be for the occasional speed fix.
Jozzer   100 kW
Post by Jozzer » Apr 17 2008 12:59pm
Hi all, i'm just repairing a dual motor controller, that appears to use the 20A miniboard (6 fets). Although the controller appears to work OK, the motor wont spin up from all positions. Sometimes it spins, other times you have to roll it back to make it fire up. Any idea's?
Steve
Mazda MX-5. 300KW power. Soliton 1 controller, 11" Kostov motor, 20KW/H Turnigy Lipo for 60-100 miles range. 120mph top speed.
Hudson Kindred Spirit 3 wheeler. Twin Agni setup, 300KG 80KW. 100mph top speed (maybe more, but no-one has the guts to try!)
Aprilia RS125, Agni motor, 600A 96v Kelly controller, 6kw/h pack
Dual Agni Ducati.
Countless ebikes and trikes..
http://www.Jozztek.com
fechter   100 GW
Post by fechter » Apr 17 2008 3:18pm
Jozzer wrote:Hi all, i'm just repairing a dual motor controller, that appears to use the 20A miniboard (6 fets). Although the controller appears to work OK, the motor wont spin up from all positions. Sometimes it spins, other times you have to roll it back to make it fire up. Any idea's?
Steve
That usually indicates one hall sensor is not working. Could be just a bad connection.
Jozzer   100 kW
Post by Jozzer » Apr 24 2008 12:19pm
Hmm, wasn't halls sensors at all, and by the time we got through a batch of 10 controller repairs, we found this fault on 2 controllers. One thing that will cause it, is the gate leg of the mosfet not soldered in properly, another was a driver chip. Strange to see the same fault with 2 different causes...
Another symptom is slightly noisier running. (rumbles and such)
Dual Agni Ducati.
