Crystalyte Controllers - Repair and Modification information
Archive of useful information. This is not a discussion area.
mikereidis   1 kW
Re: Crystalyte Controllers - Repair and Modification information
Post by mikereidis » Sep 03 2008 9:38am
fechter wrote:I think he wants to do the opposite.
I've never seen one of those controllers first hand. It would be v1 of sorts.
Look on the board and see if there is a 16 pin chip marked C1246. That's the commutator chip used on the immediate start controller. If it has one, then there should be a way. I've never fully traced out the hall sensor input circuit, so I don't have a schematic of that part (it may be posted earlier in this thread?).
From my post on the V2 controller thread: Those 3 holes on lower left look like place to attach 3 hall wires. Underneath there is a 16 pin chip that I'm guessing is upc1246 commutator. I can only see "6G" or maybe "6C" ? at end of chip number. Those 3 holes: 1 goes to pins 1 and 4, 1 to 3 and 6 and other probably to 2 and 5 so it looks like commutator chip there.
So if I can figure out the right wiring for 3 hall sensors, I just add ground and some suitable voltage point, presumably another hole near these 3, or same voltage as throttle ?
Here's the response I got from ebikes Justin:
I've never heard of anyone converting a PF to an Instant
Start model. Depending on how the board was designed it could be as
simple as attaching the 3 hall signal lines, but that isn't too
likely. If you reverse engineer the layout and figure out how the
commutation timing circuit is implemented then you could come up with
a hack that drives the phase decoder chip from the hall lines instead,
and if it is indeed using an actual hall decoder commutator chip then
this might not be that difficult, and would be a neat feat.
So maybe I'll be the first to try this mod. I'm pretty sure it's possible now. Those 3+ holes ARE there for hall sensors and I suspect there is an instant start version of this board; I just have to figure out wiring and hope it just works without messing with any jumpers for mode select.
SolarBBQ:
This IS a Crystalyte controller, bought from ebikes 1 month ago. 72v, 20a, pedal first. Sort of an oddball in the lineup IMO, because it's a 72v unit but only rated for 20 amps ? Seems funny to have 12 4110 fets but only 20a limit.
No clear markings I could really see. Will check much closer next weekend when I pull the controller and try to add this mod.
rkosiorek   1 MW
Post by rkosiorek » Sep 03 2008 10:08am
it is indeed an older V1 20A pedal first controller. i don't have one of those handy here to confirm what i suspect.
i think that the early pedal first controllers lack an item crucial to implementing a sensored controller in a simple way. they don't have a commutation chip to decode the rotor position and translate that to the drive signals. instead that is performed by some discrete analog chips and transistors.
the chip that i am thinking of is the C1246 chip. and it exists on the V1 20A and 40A controllers. it is in a surface mount SOIC-16 package. check to see if you have one of those on the board. if there is one than there is an easy place to connect the hall sensors to the controller and bypass the BEMF circuits. if it isn't there then the question of how to connect the hall sensors becomes much more complicated..
rick
DISCLAIMER:
We will not be responsible for damage to equipment, your ego, blown parts, county wide power outages, spontaneously generated mini (or larger) black holes, planetary disruptions, or personal injury that may result from the use of this material.
- Samuel M. Goldwasser -
rkosiorek   1 MW
Post by rkosiorek » Sep 03 2008 11:21am
V1 20A start immediate controller.
this is a picture of the start immediate controller. i left the Hall Sensor wires connected. there is little similarity between this and the pedal-first controller in the previous pictures.
rick
DISCLAIMER:
pwbset   1 MW
Post by pwbset » Sep 03 2008 12:01pm
mikereidis wrote:SolarBBQ:
These pedal first 20A controllers only have 6 4110s in them. I completely soldered my shunt and am seeing 55-60A spikes in the CA with 40ish sustained (which is all by battery pack is good for sustained wired 2p) and the controller is vibrating like crazy under full throttle until it gets up to speed. Don't expect it to last long, but I'm sure having fun in the meantime. :mrgreen:
mikereidis   1 kW
Post by mikereidis » Sep 03 2008 1:58pm
rick
Thanks rick ! That's almost exactly my board, except yours has a few extra connectors where mine only has holes for the non-existent connectors. I presume corner connector is halls, and next is brake switch controller kill. If you could PM me or post any other high-res pictures or pinout diagrams etc. you have, I would very much appreciate it. Looking for color coding on hall sensor plug mostly right now.
mikereidis   1 kW
Post by mikereidis » Sep 03 2008 2:02pm
rkosiorek wrote:it is indeed an older V1 20A pedal first controller. i don't have one of those handy here to confirm what i suspect.
rick
Yes, the 1246 is there, underneath the board, properly wired to the hall sensor holes where a connector is on that immediate start board. I think both boards are virtually the same. Hmm, with immediate start controller, can it do pedal first if halls are disconnected ? If someone could confirm that works, then I'm pretty sure no jumpers are on the board to cut or install.
I'm too excited now :) and will try this mod tonight. Getting REALLY tired of turning bike down on a hill (When one of my batts BMS trips uphill) and swinging back up to restart.
ngocthach1130   1 kW
Post by ngocthach1130 » Sep 03 2008 2:03pm
Guys, I have the new white board V2 controller. I upgraded to irf4110 and 200v caps long ago. Recently i upped it to 100v battery source. Ran fine for a little while. The other day while up the hill, I popped a capacitor.
It was the C8 capacitor at the bottom edge of the board with the fets on the top edge. what is that capacitor and what is the value so i can replace it. Also a trace from the C12 capacitor leading to a surface mount part close to the fets is blown. It the copper trace broke but could be mended with a drop of solder. Controller still run...Weird. Should i be worry?
Worse part of waking up...is having to stay up!
Thach(Tut)
mikereidis   1 kW
Post by mikereidis » Sep 03 2008 2:06pm
Mine has 12. :) 6 on top and 6 on bottom. Unless there are 6 other FET looking things there, but I doubt it, and board traces tell me they are probably FETs. I can't see numbers too easy. I'm wondering if there is a 35 or 40+a version of this board with nothing different except current shunt. 1 board makes for lower production and inventory costs, even if the extra FETs cost a few bucks in volume.
I'm still REALLY surprised a 20a controller has twelve 4110 FETs. I imagine it should be easy to run this at 30-40a with only a shunt mod.
pwbset   1 MW
Post by pwbset » Sep 03 2008 2:16pm
mikereidis wrote:Mine has 12. :)
:?: I got mine just this past May? Sure looks the same as yours. I most definitely only have 6 FETs.
mikereidis   1 kW
Post by mikereidis » Sep 04 2008 2:09am
I got mine one month ago from ebikes for $145 + gst + shipping. They didn't and still don't seem to have the immediate start version of this controller. C7220PF http://www.ebikes.ca/store/photos/C7220PF.jpg They seem to have some in stock again now: 8 allegedly.
Aren't these 6 additional FETs under the board? Yes, there is a voltage reg or something sandwiched on top of left FET and something on right FET.
Here's a side view. Screw on right is or first FET with VReg (?) sandwiched on top. That's the commutator chip you see under the board there.
Screw at left is for rightmost of these 6 FETS:
mikereidis   1 kW
Post by mikereidis » Sep 04 2008 2:18am
I connected the hall sensor lines, and powered the halls with 5 volts, since that's what the spec sheet seems to recommend.
Immediate start did not work. When pedal start engaged, the motor made a few noises but wouldn't spin. I disconnected the 5 volt supply and it returned to normal pedal first.
I'm thinking there must be (a) jumper(s) or resistors to cut or something. I'm thinking the motor 3 phases (at FET connection) are conditioned and fed to commutator. This would explain my 7 KMH pedal first start speed perhaps, since my motor should generate about 5 volts at that speed.
So I think I just have to interrupt the back EMF signals from the motor. Clearly, this board was designed to be usable for PF and IS. So I know this is probably possible, IMO.
rkosiorek   1 MW
Post by rkosiorek » Sep 04 2008 8:25am
you probably have to remove the 6 resistors used for the BEMF sensing. they would be confusing the hall sensors. not sure but i would suspect that the resistors are the neat group of 6 resistors placed on the left edge of the board just below the big capacitor.
the hall sensors would also need a pull up resistor to the 12V supply going to the chip. on my IS controller these resistors are 18K.
since you are the only one with a board could you trace out the schematic of the pin connections going to pins 1,2,3,4,5 and 6 of the C1246 chip. pin 1 and 2 are used for the yellow hall, 3 and 4 for the green and 5, 6 for the blue.
rick
DISCLAIMER:
fechter   100 GW
Post by fechter » Sep 04 2008 8:45am
It's hard to see on the v.1 board I have, but it looks like the hall sensors go to pins 2,3, and 6 on the commutator chip. Pins 1, 4, and 5 seem to be tied to something else (?).
Correct about removing the BEMF sensing resistors. The hall signals need pull-up resistors to the Vcc of the commutator, which would be pin 8. I think it would work if they were pulled up by the +5v supply too.
Here's a picture of an immediate start 20 amp board (from somewhere else on the forum). This is what you want to copy...
20A controller top side.jpg (122.08 KiB) Viewed 4313 times
20A controller bottom side.jpg (127.72 KiB) Viewed 4276 times
docnjoj   100 GW
Post by docnjoj » Sep 04 2008 9:00am
Richard! What are the 2 empty sockets for? (white male 2 pin and 3 pin)
otherDoc
E-bike stable at our house
Steintrike Mad Max full suspension trike rear Cute 100H going on: Whoops, Cute wheel broke but I fixed it.
Sun USX delta trike EbikeKit small geared front wheel sort of front suspension for wife
Agniusm/A123 AMP 20 36 volts on the Steini has been taken off.
2x16000 Multisport from HK now gone as they died after 2 years
New Luna 10S bottle battery 13.6AH now on mine
Relatively New 10S4Px2 for wife's bike giving 20ah @ 40 volts home made Panasonic from Tumich. BMS's rule.
rkosiorek   1 MW
Post by rkosiorek » Sep 04 2008 9:06am
the hall sensor schematic is identical to the one used for the 40A version. just the identifying Rx and Cx numbers are different. so here is a copy of the schematic for the hall inputs of the 40A version. the capacitor values are a guess and probably wrong. i also could not see the identifying numbers for the parts.
40A hall input section. same as 20A EXCEPT Rx and Cx numbers different. also Caps marked 104 are probably a lower value
V1 - HALL SENSOR INPUT.jpg (39.67 KiB) Viewed 4311 times
V1 - HALL SENSOR INPUT.pdf
(12.2 KiB) Downloaded 222 times
pins 1,4 and 5 are connected to a voltage divider to set the trip point of the sensors. the inputs for each sensor go to a comparator built into the C1246
Here is the layout of the board connectors:
and what i suspect are the BEMF resistor dividers. at least they look to be connected to the phase outputs.
bikedctrlr 004.jpg (146.37 KiB) Viewed 1483 times
rick
DISCLAIMER:
mikereidis   1 kW
Post by mikereidis » Sep 04 2008 9:58am
rkosiorek wrote:you probably have to remove the 6 resistors used for the BEMF sensing. they would be confusing the hall sensors. not sure but i would suspect that the resistors are the neat group of 6 resistors placed on the left edge of the board just below the big capacitor.
rick
Thanks Rick ! Yes, I suspected that neat group of 6 resistors. I will trace connections tonight.
I checked the hall sensor holes 2 days ago to confirm for myself it matches C1246 pinout:
A: goes to pins 1 and 4
B: to 3 and 6
C: to 2 and 5
So it appears to me it differs a bit from the schematic you show for 40a version. Instead of a voltage divider giving about 5 volts on negative side of comparators, these hall sensor lines seem to be setup in a differential mode. Perhaps this gives better EMF/noise immunity ? BTW, to hookup I used a few feet of cat5 network cable with 4 twisted pairs and each hall sensor pair is ground and sensor twisted.
Hall sensors need pullups ? If so, I'd think they'd be on the board. I will check.
If the immediate start version still has those BEMF sensing resistors, then I'd hope there was some way to disable them (or just disable their connection to C1246) without removing/destroying them. There MUST be a jumper somewhere or I won't be entirely happy. Would be nice, but not essential, if pedal first still worked if one or more of the hall sensors go bad.
mikereidis   1 kW
Post by mikereidis » Sep 04 2008 10:05am
fechter wrote:It's hard to see on the v.1 board I have, but it looks like the hall sensors go to pins 2,3, and 6 on the commutator chip. Pins 1, 4, and 5 seem to be tied to something else (?).
Thanks Fechter ! I note that the board you show has a somewhat different layout than mine, but all the major components are in about the same locations.
Should the phasing of the 3 hall sensor wires really matter for testing ? I'm trying to recall, but I think if I hooked them up wrong, it should still work, but just go backwards ? Or do I have to try all 6 combinations to see which one works for forward ?
rkosiorek   1 MW
Post by rkosiorek » Sep 04 2008 12:11pm
only one combination of hall and phase wires will work properly in one direction. and one will work in the opposite direction.
the other combinations will either not work at all or work very poorly drawing a lot of amps. the other combinations most likely will not start the motor at all unless the motor is first given a spin. it would be safest to test using a current limited power supply.
the input differential amplifiers/comparators are wired entirely differently to use for BEMF zero crossing detection than they would be for Hall sensors.
the hall sensors report a the actual position of the rotor. it is a logical function. so one side of the individual comparators would be tied to a reference voltage. the pulled up output of the hall sensor will be either above or below this reference and connected to the other side of the comparator. this signals an on or off condition. plain and simple. noise isolation is provided by the filter formed by the pull up resistor in series with the capacitor on each hall output. this is a digital approach.
BEMF detection is analog and a totaly different approach is used. the (-) input of the differential amp/comparator is tied to resistive divider that produces a floating "0" reference point that is half the voltage between the lowest and highest phase voltages. this is compared to a measured BEMF voltage. as this measured BEMF crosses the floating "0" the rotor position can be detected. there are several techniques to do this. each of these techniques uses a lot more parts than the Hall sensor input would. the wiring of the input amps is analog and specific to this arrangement and entirely different from the digital configuration used for hall sensor position reporting.
thinking that you can just simply attach digital hall sensors to inputs configured for analog BEMF detection is flawed and shows a complete lack of understanding how each technique works.
in simplest terms. all of the parts used for BEMF detection would have to be removed from the board. the inputs to the C1246 would have to be rewired to be something similar to the schematic that i supplied for the Hall sensor approach to work.
this is the reason why the boards look different. one method using the Hall sensors uses 6 resistors and 3 capacitors attached to the inputs of the C1246. the other uses a dozen or more resistors and a few more capacitors to connect the measured analog phase voltages to the same inputs of the C1246. that is why one board has a connector and a couple of parts and the other does not have the connector and a lot more passive parts.
if you want to use both on the same controller 2 different and distinct input sections would have to be designed. then some method would have to be made to select which of the 2 inputs is being used. jumper blocks? DIP switches? logic circuits? something has to be there to select which you use.
what some people have done is to build a separate analog BEMF detector circuit. this detection circuit is designed to output a digital on/off signal compatible with the Hall sensor inputs of the Immediate start controller. since the hall sensor input is digital this is easy to do.
what you are trying is fundamentally different. BEMF is an analog technique and trying to connect a digital signal to an analog input is much more complicated.
rick
DISCLAIMER:
mikereidis   1 kW
Post by mikereidis » Sep 04 2008 1:02pm
rkosiorek wrote:only one combination of hall and phase wires will work properly in one direction. and one will work in the opposite direction.
rick
Thanks Rick. OK I'll try all 6 combos and see if it magically starts working. :)
I'm operating under the assumption the designers of these controllers did everything they could to keep the circuitry and board layout as close as possible for pedal first and immediate start models. Everybody does this when possible; reduces engineering, manufacturing, inventory and other costs a lot when different products are based on the same board and everyone is out to build cheaper products these days. I wouldn't be attempting this if I thought I'd have a HUGE amount of work to do. I'd buy a new controller otherwise. This mod attempt is partly for educational reasons; perhaps I'll end up with a controller that is more versatile than the stock controllers (pedal first and immediate start switch or "auto" selectable.
I have a HUGE background of hobby and professional experience with designing, building and repairing analog and digital electronics, so I'm completely up to the task. My professional experience switched to computers/software in 1989 and my eyes aren't as good for tight soldering spaces anymore, but I'm sure I can muddle through.
I DO think this conversion direction: PF to IS should be easier than the reverse (unless you use an external BackEMF to Hall sensors type output converter.) I think the back EMF detection is essentially digital (zero crossing ?), and the outputs from the C1246 are effectively digital, so I DO think this is all essentially digital: on or off. Yes, Back EMF is an analog sine wave, but one of the first things done to this analog signal is conversion to digital, with zero-crossing or peak detection or whatever.
The pictures in this post of mine: http://www.endless-sphere.com/forums/vi ... 390#p93301 show what looks line 3 lines running from center tap of 6 voltage divider Back EMF resistors to area of c1246 and my "alleged hall sensor holes". I'll verify this and see if cutting the traces would help to remove Back EMF sensing.
I noticed last night that the voltages on the controller "hall sensor input" holes seemed to oscillate between 0.12 and 0.24 volts or so. I was thinking "confusion mode" (?). Later the voltage stayed steady around those voltages. I realized the second readings were with motor disconnected. I wonder if bike wobble was generating a small bit of AC voltage I was measuring. I've noticed before that it's virtually impossible to get accurate resistance readings from motor because just a bit of wobble causes the readings to bounce everywhere.
pwbset   1 MW
Post by pwbset » Sep 04 2008 2:30pm
mikereidis wrote:Aren't these 6 additional FETs under the board?
Heatsink I believe. I'm looking forward to seeing if you have some success with your project.
mikereidis   1 kW
Post by mikereidis » Sep 04 2008 4:26pm
Ahh, OK, thanks. :idea:
I thought they looked a little flat and plain. The screws and the tight space fooled me. :)
So it has the minimum of 6 FETs, 3 high and 3 low. All is right with the world now.
mikereidis   1 kW
Post by mikereidis » Sep 05 2008 9:14am
mikereidis wrote: I checked the hall sensor holes 2 days ago to confirm for myself it matches C1246 pinout:
B: to 3 and 6
C: to 2 and 5
Yes, halls need pullups. :) I tried some random 1-5K resistors pulled up to +5v but didn't work. Interesting observation: once I fixed one bad hall connection solder joint (insulation in hole ! My eyes aren't so good no more), then the pedal first still worked with the halls connected, with or without pullups. So at least it doesn't interfere (but does if one hall line breaks ?).
This didn't give me instant start however. I still think that no matter the combination, the motor should do something, even if just a growl or a bang or two when throttle twisted. Spinning the wheel a little will give all 6 combinations of 3 halls and at least one or two of those should make some noise.
Is pedal first minimum start speed enforced by a minimum AC voltage produced by motor ? Or does something measure pulse frequency to set the min start speed ? I think, at least, I should be able to replace BEMF sensing with hall sensing and have a hall driven pedal first setup. (I'm assuming I can make the phase offsets correct.) Once I do that, I can look for what to mod to reduce the start speed (to 1 KMH say, real easy to do) or eliminate the need for prior rotation.
I traced the connections to those 6 BEMF sensing resistors. The tap between them connects directly to the hall sensor holes and the comparator pins on c1246. Pins 1 and 4 are both negatives, 3 and 6 are both positives and 2 and 5 are one of each.
Each top resistor (I measured 38Kohms) goes directly to motor lead. Each bottom resistor (13Kohms) goes to negative bus/ground. So it seems like a simple 25% voltage divider, although probably more complex than that since 3 phase AC comes in here, and it's relative to all 3 phases, and not really relative to the negative bus/ground.
I could use the top resistors as pullups, and cut traces or whatever to disconnect them from motor. But it would be REALLY nice if I didn't have to cut components or traces, and still leave BEMF sensing there as a full time non-interfering thing, or switch selectable.
So I'm off to read C1246 app notes and learn what I can to go farther.
EDIT: Dagnab it ! The notes are in Japanese only: http://www.necel.com/cgi-bin/nesdis/o00 ... le=UPC1246
http://www.necel.com/nesdis/image/IEP-651.pdf
http://www.necel.com/nesdis/image/IEP-653.pdf
Datasheet is available in English but I already have that. Anyone know of English app-notes for this chip or very similar chip ?
ejonesss   10 kW
Re:
Post by ejonesss » Sep 09 2008 2:16am
The7 wrote:The original 48V IS controller has an LVC at 29V.
The 33k and the R6(5.1k) will be removed to de-activate the LVC so that the controller will work from 24V battery to 48V battery for my AL1020 ebike.
i was wondering can the lvc be bypassed all together to allow 12 volt operation or even use of ni cads (witch has no problems with over discharging in fact requires complete discharging to prevent memory) just by jumping a wire from the bat+ to the resistor/diode junction? (basically shorting out both resistors)?
stuff for Even Newer 4 to 24-cell Battery Management System (BMS)
32 lifepo4 cells 16s2p 40138 green cells √
16s2p 40138 based pack built assembled (building electrical equiv to $2000 eonyx system.*
fechter   100 GW
Re: Re:
Post by fechter » Sep 09 2008 8:38am
Yikes! don't do that.
If you want to disable the LVC, you could disconnect either the diode or disconnect R6, whichever is easier.
12v might be pushing it since the voltage regulator is trying to make about 14v and needs a little more than that for voltage drop. It might work however. For 12v only, you could possibly bypass the voltage regulator.
ejonesss   10 kW
Post by ejonesss » Sep 10 2008 3:33am
i havent looked at the controller closely but the only voltage regulator there may be (typical of many electronics) is a 7805 to make the 5 volts for the logic power.
