Hi all
There is no fualt in the Cycle Analyst
let me get that straight first.
This thread has been done due to the popularity of the CA and the fact there is nothing else like it out there.
The Guys at Ebikes.ca do a great job the Direct Plugin Cycle Anlyst or DP CA, when you buy a controller and a DP CA from them the settings for the shunt resistor are programed in by them,this makes things easy, however many of us started before the CA came along and so had to use devices that were designed for the R/C market, watts up,doc wattson and the power analyser family from Medusa com to mind (me I had a power analyser pro), to my knowlege most had a voltage limit of 60v mine did, so when the drain brain came along the voltage limit was off.
Now we have the DP CA that has all the features of the drain brain plus the ability for the first time to aply control to the controller.Many of us already had speed controllers and wanted to upgrade to a DP CA, with this in mind Ebike.ca added to there website pictures of how to wire 20a and 35/40a x'tlyte controllers for a DP CA at your own risk they also sell the short cable terminating in the correct plug for a DP CA.
There are now more and more controllers coming on the market and one of the first things one or other of us at ES does is to work out the wiring for the DP CA,the guys at Ebikes.ca have no knowlege of the shunt setting for all of these other controllers or if the shunt in a controller that came with a DP CA has been modified I belive you can add solder across the shunt.
So there you have it a great product with a lot of retro fits out there and some may not be giving true readings through no fault of Ebike.ca if the settings are set incorrectly then you can't expect to get the correct results out the other side, with a cycle computer if you don't put the correct circumfrence into the settings you can't expect to get an acurate speed, you dont blame the manufacturer for that do you.what I am providing is a spread sheet for exel that should help to zero in the diffrence between a know reading and a DP CA reading.
requirments for this are
exel from 2003 or later
the DP CA you wish to calibrate
a drain brain, watts up, doc wattson, power analyser or any other type of device that can mesure amphours acuratly.
I will be setting up a feedback thread in e-bikes review and testing http://endless-sphere.com/forums/viewtopic.php?f=4&t=6104 post your comments there.
