Broken EMC-1000 charger
samush
Post by samush » May 19, 2017 10:47 pm
The charger that I'm using broke after charging my 20ah pack 17 times, and most of those were partial charges! :cry:
When I plug it in the lights don't come on. Does anyone know how you can fix these chargers?
fechter
Re: Broken EMC-1000 charger
Post by fechter » May 19, 2017 11:49 pm
If no lights, noise or sign of life, you need to open it and see if there is a blown fuse or other obvious sign of smoke release.
If it's new, it may still be under warranty.
samush
Post by samush » May 21, 2017 7:10 pm
I took it apart and it looks okay, I cant find any fuses or anything burnt. I bought it 2 years ago and only started using it this year.
fechter
Post by fechter » May 23, 2017 8:57 am
Can you post a picture of the board? I'm not familiar with that model, but from a picture I might be able to pick out parts to check.
samush
Post by samush » May 23, 2017 10:16 pm
Too bad it's all glued down
fechter
Post by fechter » May 24, 2017 2:41 pm
Charger board 1.jpg (85.61 KiB) Viewed 357 times
The item circled in red is likely to be the "fuse". These are power resistors with an integrated thermal fuse that will blow if it gets too hot.
Look at the markings on the part and try measuring the resistance of it.
samush
Post by samush » May 25, 2017 4:20 pm
I found a broken fuse! I'm going to give this a try first
fechter
Post by fechter » May 26, 2017 8:22 am
OK, glad you found the fuse. If the new fuse blow immediately, you have a bigger problem.
Moto996
Post by Moto996 » Feb 05, 2018 5:31 am
Hi Guys
Just found this forum as im looking for ways to fix my EMC-1000 charger.
I've had this unit for years charging my 72v road going scooter.
in any case, my charger stopper working all of a sudden. I have checked the fuse and it works just fine, i have also checked the input cable to make sure there is input voltage and that checks out as well.
so i saw this post about the power resistor and i was wondering if that could be my issue. so i was wondering if anyone has has experience with this repair since the board is all glued in place??
fechter
Post by fechter » Feb 05, 2018 4:27 pm
Since the OP found a real fuse, the resistor thing might just be a resistor. You could try to see if there are any markings on it. If the board is all glued down with potting, it may be difficult to replace.
Does the charger light up at all?
