Elegant solution for 72v main power switch
81style   10 mW
Post by 81style » Oct 30 2018 5:30pm
Friends
Can anyone suggest an good solution for a main power switch for my 72v build? I was thinking of adding a DC circuit breaker between the battery and controller, but perhaps there is a more elegant solution? The really slick options such as solid state push button switches seem to be for 52v and lower builds.
Any thoughts?
skeetab5780   10 MW
Re: Elegant solution for 72v main power switch
Post by skeetab5780 » Oct 30 2018 6:32pm
Could use a fancy contactor with magnetic blowout, they are cheaper from China
https://www.google.com/amp/s/www.electr ... et%3famp=1
E-HP   1 kW
Post by E-HP » Nov 06 2018 4:54pm
I used one of these, but I wouldn't call it elegant. It will appear more elegant when I fabricate an aluminum channel frame around the bike's triangle, that I'll cutout to fit the breaker, but for now it's better than unplugging the battery when not in use:
https://www.amazon.com/gp/product/B000W ... UTF8&psc=1
John in CR   100 GW
Post by John in CR » Nov 06 2018 8:58pm
If your motor is a 3 phase brushless, then there should be no need for a main power switch. Instead put a simple, cheap, reliable key switch on the low power input to the controller's logic section of the controller. Even my 20-30kw builds don't have or need main power switches. Safety features include an appropriate fuse at the battery, a key switch to cut power if all else fails, and ebrake switches to easily and intuitively cut off a runaway condition without letting go of the handlebar with one hand.
Elimination of unnecessary components is always the most elegant solution to me.
81style   10 mW
Post by 81style » Nov 09 2018 12:30pm
John in CR wrote:
Nov 06 2018 8:58pm
I definitely see the appeal of this approach.
John in CR wrote:
Nov 06 2018 8:58pm
20-30kw? Wow, that's serious power! What voltages are these builds operating at? I'm using a Phaserunner on my 72v build and the remote on/off for that controller is at battery voltage (but with very low amperage), so one of my challenges is finding a switch to use here that will not be subject to arcing. Would you mind elaborating on what you use to switch your controller either here or in this thread: Remote On/Off Switch for Phaserunner V2
Chalo   100 GW
Post by Chalo » Nov 09 2018 12:39pm
John in CR wrote:
Nov 06 2018 8:58pm
Are there no possible fail-on modes for brushless controllers?
kdog   10 kW
Post by kdog » Nov 12 2018 7:01am
Throttle failure (mech or elec)resulting in WOT springs to mind. Don't know of any others in brushless. Had a few hair raising brushed controller failures on my mtn board. Crazyscarry!
Dumsterdave   100 W
Post by Dumsterdave » Nov 12 2018 8:21am
I'm using one of these with my phaseruner at 72v and it had been working fine for about 6 months. I'm a bike courier that had to turn my bike on and off about 30 times a day and haven't noticed any arcing.
Onever Universal Motorcycle Handlebar Flameout Switch ON OFF Button For Moto Motor ATV Bike
https://s.click.aliexpress.com/e/bPMPKHL2
81style   10 mW
Post by 81style » Nov 13 2018 12:05pm
Dumsterdave wrote:
Nov 12 2018 8:21am
What happened after 6 months?
Dumsterdave   100 W
Post by Dumsterdave » Nov 13 2018 1:31pm
81style wrote:
Nov 13 2018 12:05pm
Dumsterdave wrote:
Nov 12 2018 8:21am
Nothing, it's still working
81style   10 mW
Post by 81style » Nov 13 2018 1:38pm
Dumsterdave wrote:
Nov 13 2018 1:31pm
81style wrote:
Nov 13 2018 12:05pm
Dumsterdave wrote:
Nov 12 2018 8:21am
Gotcha. The "had been" threw me.
TommyCat   100 W
Post by TommyCat » Nov 13 2018 3:45pm
Dumsterdave wrote:
Nov 12 2018 8:21am
Please clarify, is this on the battery supply line? :shock: Or just in the controller ignition circuit?
See my completed Magic Pie V5 rear hub E-Bike build Here!
flat tire   100 kW
Post by flat tire » Nov 13 2018 4:46pm
No switch needed. Just plug and unplug the battery. Works well with Anderson SB50, easy to clean the contacts too.
Dumsterdave   100 W
Post by Dumsterdave » Nov 14 2018 12:04am
TommyCat wrote:
Nov 13 2018 3:45pm
Dumsterdave wrote:
Nov 12 2018 8:21am
It's connected to the 2 pin jst connector coming out of the controller
John in CR   100 GW
Post by John in CR » Nov 29 2018 9:35pm
Chalo wrote:
Nov 09 2018 12:39pm
John in CR wrote:
Nov 06 2018 8:58pm
Without power to the logic chip there's no way for the brushless motor to make positive torque. If properly wired a brushless setup would require multiple simultaneous failures to create a runaway condition. eg A short of the throttle wire combined with failure of both ebrake cutoffs, but turning off the 0.1A or so power wire supplying controller's brain stops that in short order.
A bit of plug braking due to shorted failed power mosfets has been my typical failure result, which makes a DD hubbie controller failure a pain to pedal home. Anything from water to a dropped bike or loose wire can cause a throttle failure, so they are common, therefore, ebrake cutoffs are a mandatory safety feature intuitive to use. Reaching for a key or plug to cut power to the controller brain should be just a final line of defense to kill a runaway, and really shouldn't ever come into play anyway. I like key switches as a safety to prevent curious hands from making an idle bike hurt someone which adds a bit of theft deterrence. I find switching a key off to disable an otherwise silently ready to launch vehicle quickly becomes intuitive during dismount.
John in CR   100 GW
Post by John in CR » Nov 29 2018 9:55pm
81style wrote:
Nov 09 2018 12:30pm
John in CR wrote:
Nov 06 2018 8:58pm
John in CR wrote:
Nov 06 2018 8:58pm
74V to 115V nominal. I've used motorcycle key-switches readily available for under $10 on the same type of low current switch line you're talking about for over 10 years on a variety of ebikes for myself and others without a single failure. Many of those builds include the supply for the DC/DC converter for lights on the same key-switch, so I've been a bit surprised that contacts built for 12V use have held up so well at my pack voltages. There must be something in the standard design that prevent arcing, because I've replaced numerous charge connectors over the same time frame with a small fraction of the connect/disconnect cycles.
