Help me choose a good affordable 72v controller for: 5KW QS V3 Rear Direct Drive Hub Motor
rockstar195   100 W
Post by rockstar195 » May 31 2019 8:42am
Help me choose a good affordable 72v controller for 5KW QS V3 Rear Direct Drive Hub Motor.
My options so far: Mobipus 72200, Kelly KLS7230S, Sabvoton 72200 (read bad things about Sabovoton).
hurryupnbuy   10 mW
Re: Help me choose a good affordable 72v controller for: 5KW QS V3 Rear Direct Drive Hub Motor
Post by hurryupnbuy » Nov 26 2019 2:47am
Which controller did you end up going with?
SlowCo   100 kW
Post by SlowCo » Nov 26 2019 9:06am
Get a Nucular 24F. The QS hub motor power ratings are very conservative and can handle much more. Nucular is the new kid on the block with very good results.
viewtopic.php?t=75494
viewtopic.php?t=97163
The new PowerVelocity might also be a good candidate but not yet reviewed:
viewtopic.php?t=99621
Jonno   100 W
Post by Jonno » Nov 26 2019 5:44pm
I'll second that. Go for the 24F nucular. well worth the wait. having used Sabvoton,APT, Infineons etc, the 24f is fantastic
Jonno
Modified EEB frame, 888 forks, 280mm DNM pit bike shock, QS273 40h V3 , Nucular Electronics 24F controller 300a, 92V @ 36ah 26650 cells, 300a BMS,
Hope V4 + Galfer 223mm discs + Variable regen braking.
Latest project: Sur-Ron 84V 30ah Battery, Nucular Electronics 24F controller, Hope V4 + Galfer 223mm discs + Variable regen braking.
larsb   1 MW
Post by larsb » Nov 29 2019 1:26pm
Also going for the 24F nucular even if i never used one.
Votol em72150 for cheaper option. 200A battery, 370A phase. Unlocked. I am currently running 250A through one since some time.
