Anyone ever use this program?
ebike11   100 kW
Post by ebike11 » Jun 10 2019 3:24am
Hi guys
Could anyone help me out with this program? I emailed the aliexpress seller but got no reply. Its a programmable sinewave controller. Voltage can be set anywhere from 48v to 96v. I programmed the voltage i want but trying to tune it more. I also have a sabvoton but Im comparing both at the moment. This controller doesnt have bluetooth programming so i must connect to my computer. I know that with my sabvoton that i can "enable flux weakening" and i set the amps a bit higher to get a bit more top speed..so Im thinking on doing the same with this controller. In the lower right corner shows Flux Control. Im guessing the first option is the main one but I have no clue about what all 4 are for. With the sabvoton there is only on and off and set the Amps.
Not sure if i need to play around with anything else besides flux. Just trying to the most maximum power.
Here is a pic of the program:
https://postimg.cc/N9TR5cbK
