Pizzabroodje
- Joined
- Oct 1, 2018
- Messages
- 67
I already emailed Em3Ev about the problem but because of their slow response time I decided to post it here too:
I installed the kit and battery two days ago. (Battery in the included bag for now)
It worked fine two days ago, and when I got home I charged it to 100%.
Yesterday I wanted to take it out again, but it didn't want to turn on. The on/off switch on the battery lit up when turned on, but when turning on the BBSHD using the displays button, the battery turns off, including the light on the on/off switch. I checked all the wiring but couldn't find any faults. It still wouldn't turn on.
I charged it for about a minute, and afterwards it turned on again. Then I rode it but noticed the speed not registering. After about 3 minutes of riding I got error 21 on the display and PAS and throttle stopped working. When I turned it off and back on it worked again for a short period of time.
I checked the sensor, and it's connected properly, but the light on it doesn't turn on no matter where I hold the magnet.
I let the bike sit for a while, and wanted to see if it suddenly started working again, but it was back to the first problem of not turning on again (and having to be 'jumped' to work again).
Today the BBSHD still wouldn't turn on, so I charged it for a minute again. After that it turned on again, but still no speed detection, so I tested someone else's sensor. That one also doesn't work on my bike, while it does on his.
I checked the BMS app, and everything seems fine there. Right now it's charged to 98% and 57.8v, and all cells are balanced to 6mah difference tops. At 100% it was at 58.7V.
I also noticed the motor will continue to be able to turn on after having charged it for a minute, but if I try to turn off the battery using the button, it doesn't appear to be doing anything. However when I turn on the motor again the battery turns off, leaving me stranded at the first problem with currently the only solution being charging the battery for a minute or so.
I just tried that again, and this time the off button worked once (with the display on this time). Afterwards I was able to turn on the battery and motor again. Then I tried it again, turning it off and on again, and this time the battery would, and the motor wouldn't turn on, so the same as it was before charging for a minute.
