eta: I looked at the video again and I'm not certain he didn't break the ones he was prying on. It might not be visible but there is movement in corner of the one magnet.
Bafang once again made a change, actually inproved the first version that has had a lot of failures. April 2019. Different size bearing. Needs changing for backwards compatibility.
OFFS, nothing broken. Promise. Demonstrated for most of us without a puller that fit. Nothing I have none that did. Obviously if you do have the right puller...
