Vikingimike01
- Joined
- Mar 31, 2019
- Messages
- 48
Hey guys! I have an 5000W RisunMotor kit, the controller is an "36 MOSFET 100A"
It has a 750c display. QS205 hub.
There is an option to set the wheel size. Do I set rim, or do I set tire included? I measured, it's 74cm so like a 29" with the tire.
Without the tire, it's a 26" rim. This is my first problem because I don't know if it shows the proper speed or not.. If i set it to 29" i am almost going 45 and it says 28-30
My second problem. How do I get rid of the speed limit of 25-28 KM/h? I don't think it's programmable.. Thank you all!
Edit: So, there are some options in the display. It has 4 power modes: Eco, Standard, Power, and Maximum. There are also 4 regens for hub motor regenerative braking, same. And, I can set Pedal Assist Levels to either 3, 5, or 9. I have it at 5. I noticed, in Standard mode, if I have it at the first PAS, i'll go 24, if I have it at 5, I'll go 28. Wich is more like 40 tbh. I had a motorized bike with a legit speedometer that was mechanic. I was going about 40, so about same with ebike.
