Planning a new project based on a KMX trke. Here's what I've got in mind:
Most of the MXUS 3K builds I've read about have controllers that deliver 100amps plus - whereas the Phaserunner's recommended max continuous is 45 amps (maybe more if properly cooled). Even at 45 amps I'd have in excess of 3kw, which is plenty for my purposes.
So... is there something I've overlooked? Would a controller with higher current ability than the Phaserunner be a better choice, even if max continuous current draw is set to 50 amps or less? And if so, which controller should I consider?
Main reason I'm keen to use the Phaserunner and CA combination is because I've had good experience with them on my mid-drive 2 wheeler. Plus I'd like to take advantage of the proportional regen they can deliver with a DD hub motor.
- MXUS 3K V3 hub motor built into moped rim (rear wheel drive)
- 72v 30ah lithium ion battery
- Phaserunner controller
- Cycle Analyst
