Is this normal for a motor to do? Video clip
ebike11   100 kW
Post by ebike11 » Aug 24 2019 9:32am
Hi guys
I just had the cover off of my qs205 to install ferrofluid. I noticed there is slight play/movement from side to side. Is this normal or should the motor be solid in place? Thanks
https://vimeo.com/355714234
eee291   100 kW
Re: Is this normal for a motor to do? Video clip
Post by eee291 » Aug 24 2019 11:54am
This is perfectly normal, the axle is held firmly by the two sidecovers, with just one sidecover it's impossible for one bearing to keep the axle from moving a little.
Drunkskunk   100 GW
Post by Drunkskunk » Aug 24 2019 11:20pm
Yep. there is suppose to be an air gap all the way around, between the stator and the ring of magnets. But they are powerful magnets. with one cover removed, they will pull the stator to one side.
