Power velocity wiring help
BillyJ   1 mW
Post by BillyJ » Sep 01 2019 7:55am
Hi all,
I have a powervelocity controller and wanted some help with wiring.
3 main questions:
1. The ignition input plug has an orange and a red wire, what signals go in here? - I have a switched 72V signal which I would assume goes on the orange side but what is on the red side?
2. does the throttle input to the controller remain unconnected when passing the throttle input through the BT module
3. Has anyone got some kind of DIY manual as information online is sparse and often unclear.
Also quick side question:
MXUS V3 temp input is on the white wire but when measuring resistance between the white wire and black hall sensor GND, I get no measurement on both sets. Am I doing something wrong?
BillyJ   1 mW
Re: PowerVelocity controller review
Post by BillyJ » Sep 02 2019 1:14pm
Hi guys,
I'm desperate for some help wiring up my 15kW PowerVelocity controller hence posting this here!!
There are a few places I'm stuck:
Also would be good to know:
Thanks so much to anyone that helps!
Dash is being 3d printed as I type and this is the bike:
MJSfoto1956   10 kW
Post by MJSfoto1956 » Sep 02 2019 2:50pm
BillyJ wrote:
Sep 02 2019 1:14pm
Nothing on the red side. Just send a switched 72V to the orange you should be good to go.
BillyJ wrote:
Sep 02 2019 1:14pm
Yes. There is no need to also connect the throttle to the controller if it is already connected to the PV BT module.
That being said, here's how I wired mine:
NESE Modules 20p pack.v7d.1500.jpg (471.06 KiB) Viewed 2147 times
Voting has ended: viewtopic.php?f=26&t=102697
Слишком мало, слишком поздно
BillyJ   1 mW
Post by BillyJ » Sep 02 2019 3:13pm
You're an absolute legend!!
Thank you so much! Here is mine:
(How did you wire up the thermistor, I can't measure anything between either set of white temp wire and black wire... )
MJSfoto1956   10 kW
Post by MJSfoto1956 » Sep 02 2019 4:22pm
BillyJ wrote:
Sep 02 2019 3:13pm
Motor or controller thermistor?
M
MJSfoto1956   10 kW
Post by MJSfoto1956 » Sep 03 2019 3:58pm
BillyJ wrote:
Sep 03 2019 3:39pm
Motor temp sensor on a MXUS V3 :thumb:
Not sure, but I have a funny feeling that this link might shed some light on the matter (even though it is about QSmotors): https://electricbike.com/forum/forum/ma ... analyst-v3
Also this thread seems to suggest some avenues for you to explore: viewtopic.php?t=76133
larsb   1 MW
Re: Power velocity wiring help
Post by larsb » Sep 03 2019 11:59pm
Did you ask seller? I bet they can help you!
Ride on!
BillyJ   1 mW
Post by BillyJ » Sep 05 2019 3:24pm
MJSfoto1956 wrote:
Sep 03 2019 3:58pm
BillyJ wrote:
Sep 03 2019 3:39pm
I found my problem...
The seller on AliExpress didn't include the sensor as "I didn't ask for it"?!?!?!?!!? it's also only a 10$ increase in price.... but obviously they still put the white wire in there to play with your emotions!! :evil: :evil: :evil:
MJSfoto1956   10 kW
Post by MJSfoto1956 » Sep 06 2019 8:29am
BillyJ wrote:
Sep 05 2019 3:24pm
Yeah that is a common trick endemic of much of AliExpress. I even had a Proforma invoice from one vendor that listed a rotor was to be included in their hub motor package. But after payment via PayPal, he sent an email showing some pix of what was going to be shipped and just needed confirmation on my shipping address. I missed that the rotor was not in the photo. When the package arrived without the rotor, I complained. But his first reaction was "but you approved the photos". I reminded him that I had a Proforma invoice that listed the rotor and he had to eat it. Lesson: if the order is custom and/or complex, be sure to get a paper trail.
YMMV
M
BillyJ   1 mW
Post by BillyJ » Sep 19 2019 4:54pm
larsb wrote:
Sep 03 2019 11:59pm
I figured it all out through another forum user. The seller can be quite unresponsive but the hardware is great.
