Without a display? I want to try PAS only, without throttle or display. But PAS is horrible. It takes off to quick and sudden, it took off when I was sitting idle and put too much pressure on the pedal.. with the handlebars at too much angle, and threw me hard past the bars... and it keeps powering for a few seconds after pedaling stops which is mostly ok so far but a bit dodgy around heavy/slow/ foot traffic. I ride it all times feathering the brake while in PAS mode.
Would I find a controller factory set up to offer better PAS? (36v/250W)
Or be able to modify my current controller in some way?
Or even.. are different PAS rings better than others (eg.12 pole v's 6)?
cheers
cheers
