Cyclone Motor doesn't turn, (with 2000W KT Controller)
jnlk6   100 µW
100 µW
Post by jnlk6 » Nov 02 2019 11:37am
My cyclone motor (1800-3000W) doesn't turn, by hand I can do it with any problem. The motor makes noise, but it won't turn. I have it connected with a KT-Controller which I ordered on Aliexpress from Passion Ebike. It has a white wire on the hall sensor cable, which I couldn't connect to the motor, because there isnt 6 cables, only 5 (the white one doesnt exist). So I'm not sure if the controller cannot controll the cyclone motor. Because, the key and the throttles work. Only when I twist the throttle the motor only give a high noise from it. Could it be, that I have to connect the Green to Yellow and Yellow go green? I read about it.
Voltron   10 MW
Re: Cyclone Motor doesn't turn, (with 2000W KT Controller)
Post by Voltron » Nov 02 2019 12:35pm
Yes.. It might be the color codes don't match. The white is usually a speed sensor and shouldn't stop it from working. You have to switch the bigger phase wires, and the corresponding Hall wires. Making an actual written chart of combos already tried helps a lot. I think with a Cyclone if it runs backwards it won't matter with the freewheel, but watch it for bikes with a direct hookup to the cranks or a hub motor... The unexpected backwards spinning can cause some chaos.
jnlk6   100 µW
100 µW
Post by jnlk6 » Nov 03 2019 7:11am
Ok thanks Sir. I will try it out! And couldn't it be that the controller doesn't work with the cyclone(, but I dont think so)?
ScooterMan101   1 MW
Post by ScooterMan101 » Nov 03 2019 6:09pm
I have the 2019 Cyclone 3k motor from GNG , Since I already had a couple of controllers I did not buy the controller at the same time / from GNG,
So
This is what I went through , ( scroll down about 60% down the page to where I write about backwards running and read all posts after that )
... viewtopic.php?f=28&t=98940
My first conversion ... Sold
viewtopic.php?f=3&t=71378&p=1077497&hil ... 1#p1077497
It's 2018 already, ( now 2019 ) lets get some real , improved e-bike / e-velomobile / e-motorcycle designs .
