Instant Start 18 fet Infineon Boards are here...
methods   10 GW
Post by methods » May 15 2009 2:49pm
We now have 30 of the 18 fet instant start controllers.
These are MUCH better in many ways than the last batch of 18 fet slow start boards
18 fet fast start.jpg (51.16 KiB) Viewed 23576 times
Notable major improvements:
- Instant Start
- Programable
- High Power wire routing corrected (interference with caps/exit hole)
- 4 shunts
- Insane capacitors
- Good up to 24S lipo (100V)
- >>100A. We will test them to destruction :twisted:
- etc (4110's of course)
Gary will receive the first completed board.
Look to Gary to start a review thread on these fine controllers
Please dont start asking if you can "Get One"... Gary will be in charge of that.
I may release a few "kits" to people around here who can test them to the limits.
-methods
Increasing battery voltage and controller current limit will result in a non linear experience
Doctorbass   100 GW
Re: Instant Start 18 fet Infineon Boards are here...
Post by Doctorbass » May 15 2009 2:52pm
:twisted: :mrgreen:
Can you confirm that the case and mosfet holes footpring and dimensions is the same as the previous 18 mosfet controller?
In other words, does the alluminium bar for sinking heat of the mosfet and the distance between mosfets is the same as the older version with soft start?
Doc
CURRENT PROJECT: 2WD duo MXUS/Max-E ebike 32kW
http://endless-sphere.com/forums/viewto ... =3&t=65764
-Fastest speed record 117 km/h on flat
-Fastest 1/4 mile@ 114km/h on flat and 16.316 sec
113kmh Gianthttp://www.evalbum.com/3406
Mongoosehttp://www.evalbum.com/1947
YOUTUBE---https://m.youtube.com/user/Doctorbasss
I speak FRENCH and english
methods   10 GW
Post by methods » May 15 2009 3:01pm
I have had these for a month.
Now I can release them
-methods
methods   10 GW
Post by methods » May 15 2009 3:09pm
Doctorbass wrote::twisted: :mrgreen:
Doc
The heat sink and case are nearly Identical.
They can probably be interchanged.
They are hand tapped though, so each is slightly unique and requires tuning during assembly.
This happened last night so....
The builds may not go as fast as they were going.
-methods
wanders   100 W
Post by wanders » May 15 2009 3:18pm
Oooh, broken ring finger, hope you are OK, Methods!
Will Keywin be selling these, or do you and Gary have an exclusive? I want one.
Is there any chance you could get a less fuzzy pic of the front (SMT) side of the circuit board?
Willie
methods   10 GW
Post by methods » May 15 2009 8:35pm
That's Keywins picture. I suspect it is fuzzy for a reason.
My boards have caps on them so you wont see the details.
I will take pictures later.
Keywin will have these but maybe not for a little while.
He is still developing the software from programming them.
I got these early on a special deal.
Gary and I are going to populate these with 4110's, Crystalyte compatible connectors, proper marine grade 10 AWG copper, a power switch, CA tap, built in USB, and a few other things.
I cant speak as to what version Keywin will be selling.
-methods
wanders   100 W
Post by wanders » May 15 2009 9:48pm
methods wrote:Gary and I are going to populate these with 4110's, Crystalyte compatible connectors, proper marine grade 10 AWG copper, a power switch, CA tap, built in USB, and a few other things.
Sounds ideal, though in my case I would do with bare copper and skip the Crystalite connectors. Otherwise, perfect, and perfect for most enthusiasts on this board in any case.
Will you divulge if the uC is still the Infineon XC846, or is it upgraded to the '866?
Willie
methods   10 GW
Post by methods » May 15 2009 11:23pm
XCKJ8B116A
09122
More memory, more I/O, more features.
At this point we dont even know what all the new features are.
Everything is bigger and better.
They even did smart things like grouping the Throttle, Brake, Hall, etc. all together right by the exit hole
Power and ground now clear the main capacitors without interference
More holes everywhere - for instance 3 holes for ebrake.
-methods
methods   10 GW
Post by methods » May 15 2009 11:25pm
The mother-in-law just showed up from out of town for wedding planning :roll:
Maybe if I get them to drink wine they will pass out and I can get some more work done.
-methods
voicecoils   10 MW
Post by voicecoils » May 15 2009 11:50pm
That sounds perfect. A number of us will be looking forward to these becoming available!
Is it possible to get an LED status light or one that blinks out error codes to the front of the case? Will the CA tap make current control from the CA? The CA connector keywin added to my 12fet infineon does not.
The thought of having 'no cut corners' in the connectors, wiring, caps actually glued down properly, etc is very appealing. Good work 8)
methods   10 GW
Post by methods » May 15 2009 11:51pm
Note that the only wires crossing the board are for the CA.
Those are BAT+, GND, SHUNT+, SHUNT-
Everything else is grouped so nicely!
The only thing I have left to do on this controller is:
- Solder in the phase wires
- Solder on Anderson
- Solder wick copper on the traces
- Clean everything
- Test
- Re-glue the caps
- Drill hole for the button (which is sealed via a rubber nut cover)
- Heatsink compound
- Reassemble
- Test
We need to characterize the shunt and decide if it will be acceptable for high current
(not likely - 100A^2 * 1mOhm = 10W -> This may be ok for burst but certainly not for continuous)
I would like to find a high quality, high power, low cost shunt. Suggestions?
-methods
liveforphysics   100 GW
Post by liveforphysics » May 15 2009 11:56pm
Looks great Methy!
This is exactly the product the E-bike world was missing.
You are doing a lot to help E-bikes and electric transporation to get a foot-hold in this world.
I can't wait to feel a pair of them driving my motors!
-Luke
methods   10 GW
Post by methods » May 16 2009 12:27am
voicecoils wrote:Is it possible to get an LED status light or one that blinks out error codes to the front of the case?
There are at least 4 points on the board for LED outputs. We can consider an LED error code output but it would probably be in the case, not external. If enough people request this I can drill the case for an indicator.
voicecoils wrote:Will the CA tap make current control from the CA?
Of course.
voicecoils wrote:The CA connector keywin added to my 12fet infineon does not.
That is because he hooked the Throttle Control line to the Ebrake. This is the old-school way of doing it.
All you have to do is pull the wire from Brake and add the diode-resistor combo described in the CA manual.
I dont use the CA current limiting because it does not react fast enough with high power systems. I prefer to use hardware limiting.
voicecoils wrote:The thought of having 'no cut corners' in the connectors, wiring, caps actually glued down properly, etc is very appealing. Good work 8)
There are places where we could be "more extreme" but I think it starts to dip into diminishing returns.
We considered 8 AWG wire but it is just too damn big, wont fit into 45A Anderson connectors, and basically requires 75A Andersons which are huge overkill.
We considered wiring in all the functions like Cruise Control, Regen, Multi-speed, LED Indicate, etc. but I think that simplicity is better, cleaner, and more reliable. We can add those features upon request. I was considering bringing all those features out on one large connector and leaving it to the user to chose what functions to use. For now we are going to keep it simple for the serious ebike folks.
I too am looking forward to another controller that I have confidence in. The Kelley is confidence inspiring because it is ROCK SOLD. I would like to create the same sense of confidence in a smaller, cheaper package.
-methods
voicecoils   10 MW
Post by voicecoils » May 16 2009 2:12am
Your choices all makes sense in terms of features to include and exclude. The Infineon boards seem to offer a wide range of functionality in their hardware & software.
I think an LED for error codes would be a valuable addition. Perhaps include it internally on long enough wire that the end user can drill their own hole and mount it themselves. It would save you the trouble of drilling and fitting it and save the buyer the trouble of figuring out which points on the board to use and soldering it up.
With the CA current limiting, while it's not instantaneous, it does function well as a 'energy saving' mode. It can let you run at reduced acceleration capability while maintaining the same top speed. I've found it useful for getting more distance from a battery pack and limiting heat build up in the motors. I can see how it would not be suitable as an absolute current limiting function for some purposes though.
GGoodrum   100 MW
Post by GGoodrum » May 16 2009 2:27am
Boy, you've been busy today. :wink:
As soon as we get a little testing done, they will be available. Eventually, I'll list the completed units on my website. For now, PM me if you are interested in getting one of these "Infineon II" finished models. The pricing is not fixed yet, until we get all the costs together, but it will be under $200. For custom and/or board-only option versions, PM methods directly.
As I mentioned in a couple threads, there will also be "package deals", with a controller and an Astroflight sensored 3210 or 3220 motor, at a pretty good savings over each one individually. We're also looking into adding a CA as an option.
Bummer about the finger, though. :shock: I hope you didn't get any blood on my board... :mrgreen:
-- Gary
wanders   100 W
Post by wanders » May 16 2009 10:19am
Hmmm, it is not clear to me that this is actually an Infineon micro-controller. Xie-Chang (the OEM) clearly did build XC846-based controller boards, but the part number "XCKJ8B116A" only shows up on the Xiechang website. There's lots of other stuff there, too, for instance part placement diagram (attached), but it is mostly in Chinese and Google does only a fair job on it. Maybe this is an Infineon XC846 knockoff?
EB218-A-1贴片位置图.pdf
(53.4 KiB) Downloaded 673 times
Willie
methods   10 GW
Post by methods » May 16 2009 10:21am
GGoodrum wrote:Bummer about the finger, though. :shock: I hope you didn't get any blood on my board... :mrgreen:
I am going to finish this board this morning and burn it it.
If it can do 88.8V @ 100A burst I will send it to you.
First I am going to try to blow it :twisted:
Hope I dont blow my 9C trying :shock:
-methods
methods   10 GW
Post by methods » May 16 2009 4:05pm
This build took too long from start to finish.
Doing everything "right" takes a lot of time. . .
Wicking all the traces, mounting a switch, calibrating the shunt, working with larger gauge wire....
People who buy these "complete" will need to understand that there is a big difference between this controller and what you get off the shelf from Keywin.
I am going to go out and break it in now.
I have a 24S 88.8V Lipo pack
I am going to run it on a 9x7 Front 9C
I have the current limit set at 100A so I should be able to see bursts to 8KW
Obviously a lot of this will be heat but the controller does not know that...
I ran the controller on my test stand and the free-wheel current was a little high...
Does anyone have test data for a 9x7 9C @ 88V ?
-methods
Doctorbass   100 GW
Post by Doctorbass » May 16 2009 4:23pm
methods wrote:This build took too long from start to finish.
-methods
I tested the 9C 9 x 7 at 75V in the delta mode and reached 3kW for one minute ,, the motor was like 45 degree C
at 100A you will certainly burn it... :twisted:
Doc
Doc
Microbatman   1 kW
Post by Microbatman » May 16 2009 5:43pm
Very nice work Methods
Looks great!!
How did you fasten the 10guage wire in connectors? Crimped Soldered
How tight of a fit was it?
Reason I ask is that my 12 guage wire was a tight fit in the anderson connectors and bearly fit into the plastic plug.
Im thinking 10 guage was quite the challenge
MotorCrystalyte X5304 20 Inch Rear Wheel DISC Brake Controller Crystalyte 48A72V4110MOSFETS
Batteries A123 24s2p
Charger Mastech 5020
Frame Azonic Steelhead
Grateful/fortunate/blessed to have the resources and family support to enjoy my ebike hobby
methods   10 GW
Post by methods » May 16 2009 6:37pm
Microbatman wrote: How did you fasten the 10guage wire in connectors? Crimped Soldered
It is a nightmare... it blows my mind that they market those 45A connectors as "10 awg"
Total nonsense! Maybe with the $50 crimper
I have to first crimp them with my crimper then carefully inspect the connections
The hole gets smaller side to side but not on top so any slack must go up
After I get them crimped just so I solder them.
After soldering I take the sanding wheel on the dremel and take a few thousandths off the very top
After doing all that work about 7 out of 10 will plug right in nice and loose.
The other 3 require inspection and correction
-methods
greasypants   10 W
Post by greasypants » May 16 2009 7:50pm
You can do it with a $10 crimper and then reshape it with a pair of vise grips but it is a tight fit.
Doctorbass   100 GW
Post by Doctorbass » May 16 2009 9:47pm
Method, What i do for real 10 gauge with 30A anderson is that i only solder them.. it is so thight than just soldering them give a very low resistance lost...
You can enlarge a bit the hole in the connector to allow the full size of the 30A anderson connector.. .I use a long nose plyer nd enlarge it and it fit well..
time saving!
I use them with my 37A CC-CV charger with my battery and at 37A it not really get hot.. just a little watm.. ( the 10gauge dissipate well the heat)
Oh.. I forgot... YOU DID A NICE JOB ON THE NEW CONTROLLER!! :wink:
Doc
methods   10 GW
Post by methods » May 18 2009 11:38pm
First Test Results
So I had a few issues getting started :roll: but now I am getting down to business.
Current Limit: 30A for this first test
Test Motor: Front 9x7 9C from Amped Bikes in a 26" wheel
Test Battery: 24S 2P 88.8V 10Ah Lipo
Monitoring: CA calibrated to the shunt
Bike: The wife's woman's Walmart full suspension bike
I started with the battery charged up to 90V
@ 90V and 30A I am seeing between 2100W - 2600W
Lets take this opportunity to clear up a misconception!
There is absolutely NO ISSUE with rideability with this controller!
I can start off as smooth as butter and I can ride as slow as 2mph
And this is about the worst possible situation... I am running a high KV motor with high voltage.
Running a lower KV motor or a lower voltage will effectively increase the throttle resolution.
Throttle Response
Response is great!
Not as good as a Kelley, but good. With the Kelly you can tune the response to be explosive. The response of this throttle is more than adequate for racing. If you are an aficionado you can definitely detect the lag but it is on par with a good ICE response. Your brain will calibrate it out in no time. Twisting the throttle gives a solid snap with powerful authority.
In the next couple of days I will try 60A, then 90A, then 120A
If the motor does not smoke I will try 150A, then no current limit at all.
All at 88V
This will be slow going though as I worked my ass off to build this controller right. I dont want to smoke it without collecting some quality data first :P
This will be a D-Test though.
I am not going to stop till I show what this thing is capable of.
-methods
steveo   1 MW
Post by steveo » May 19 2009 12:57am
methods wrote:First Test Results
Throttle Response
Response is great!
All at 88V
-methods
Hey methods
If i showed you my 12 mosfet 4110 shunt i had on my first x-lite controller you would of been :O ... at 66V .. i draw 110-115amps .. that controller never blow and i ended up selling it.....
My most powerful controller is my diy to-220 mosfet controller modded to fit 4568 to-247 package fets lol ... Max i draw was 125 amps through my watts up metter lol .. I could of gone more .. but wow .. i was surprised i didn't melt anything load testing .. my front weel was skitting on ashpahlt as i gave it full throttle.. and full brake to load test the controller lol
150amps on this 18 mosfet should be fine
What i can not stress enough is making sure you have 100% thermal contact ..
I've had over a dozen controller blow due to poorly machined sinks that where warpped .. CHECK THAT BUS BAR .. put it on a flat surface .. see if any of the ends rock .. put a flat edege to the bus bar and check if its flush by eye ..
properly thermal paste everything .. Done overkill on the paste .... just put enough!! can't wait to see your results!! .. What are you load testing with .. x5? lol .. don't burn out another one methods lol
-steveo
Repair Thread
http://endless-sphere.com/forums/viewto ... =3&t=27170
Hub Monster bike ~ 24s7p A123 15.4ah/18kv Six Phase Motor/Dual Max-E Adapttos/32kw~42.91Hp/Est 140LBS
X6 Kmx Trike ~ 24s4p 20ah/X6 MHM 602/Infinion EB324 IRFB 4110/20Kw~26.82Hp/Est 120LBS ~SOLD~
Lightening rods bike ~ 18s2p 10ah/1500w Inrunner/Infinion EB312 IRFB4110/2KW~2.68hp/Est 60LBS
EV Outboard ~ 12s8p 40ah/5KW GM Inrunner/Infinion EB324 IRFB 4110/18Hp Evinrude Drive/Est 100lbs
http://www.youtube.com/user/trdfreak03
