Which controller (with display) for the cyclone 1800-3000w motor?
jnlk6   100 µW
100 µW
Post by jnlk6 » Nov 21 2019 5:56am
Hi guys,
At the moment I have a controller from Passion eBike:
https://de.aliexpress.com/item/32608837 ... b201603_52
This isn't working with the motor, or I have an issue somehow.. The motor hums when I twist the throttle, nothing more. With the controller it came with, the cyclone was working. So when I would need to buy a new controller, which one should I buy. I definitly want a display. Or how can I bring the controller which I have now to work?
My setup:
52V, 24ah Battery
Controller 45A continious, rated 2000W
Cyclone motor 1800-3000W
KT-LCD8s
Thanks for every help
minimum   100 W
Re: Which controller (with display) for the cyclone 1800-3000w motor?
Post by minimum » Nov 21 2019 7:16am
Nucular 6F
Tommm   10 kW
Post by Tommm » Nov 21 2019 2:00pm
Cyclone sells yuyangking controllers with their motors. No display so make sure you get a bluetooth version. That way your phone will be the display if required.
TommyCat   1 kW
Post by TommyCat » Nov 21 2019 2:13pm
No "learning" function... sure you have the phase to hall sensors connections correct?
Regards,
T.C.
See my completed Magic Pie V5 rear hub E-Bike build Here!
E-HP   100 kW
Post by E-HP » Nov 21 2019 2:14pm
jnlk6 wrote:
Nov 21 2019 5:56am
What was you process for wiring the controller to your motor; specifically, how did you match up the hall sensor wires?
jnlk6   100 µW
100 µW
Post by jnlk6 » Nov 21 2019 3:09pm
So, thanks for all the replies at first.
I heard of connecting "Green to Blue" or "Blue to Green."
Until now I didn't have time to try it out. I was unsure if this can solve the problem as easy as that, so I kept asking on this forum. But know I really think this is the problem, I'll try it out this weekend.
Thanks for all the help, and especially for the nice diagram of how to solve it.
jnlk6   100 µW
100 µW
Post by jnlk6 » Nov 21 2019 3:10pm
Tommm wrote:
Nov 21 2019 2:00pm
Ok, I didn't know that. I saw some YuYangKing controllers on aliexpress.
Thanks!
jnlk6   100 µW
100 µW
Post by jnlk6 » Nov 21 2019 3:13pm
E-HP wrote:
Nov 21 2019 2:14pm
jnlk6 wrote:
Nov 21 2019 5:56am
I connected each Hall-sensor cable with a gold plated plugs (I think 2mm ones) and the phase wires with 4mm, I think, the battery with an XT90 plug. I'm sure they were connected right. But I will now change the Blue and Green phase wires and I'll see if this helps.
Thanks!
999zip999   100 GW
Post by 999zip999 » Nov 22 2019 9:05am
Have you connected the G to G and Y to Y and B to B ?
goatman   10 kW
Post by goatman » Nov 22 2019 7:52pm
I would open up both controllers to see if the same color phase wires are serving the same set of Fets. A,B,C. wire it the same way, do the same with the hall wires. always works for me
HK12K   10 kW
Post by HK12K » Nov 24 2019 12:29pm
goatman wrote:
Nov 22 2019 7:52pm
I don't think I've seen anyone actually suggest this, and it's a great suggestion. Seems a much more elegant solution than trial and error, all things considered.
jnlk6   100 µW
100 µW
Post by jnlk6 » Nov 27 2019 2:53am
999zip999 wrote:
Nov 22 2019 9:05am
At the moment, yes. But I'll try to switch Green and Blue, and see if this helps.
