transposon
While riding in the rain, my motor began to cut out and then start up again with no change to the throttle. The periods of no power became longer and longer to where now the motor is off more than it is on. I wasn't able to go above 10 mph. Here are my specs:
1000W DD generic rear hub motor
KT LCD 5 controller
2 6S lipos in series.
I only have just over 100 miles on the motor.
One thing that did happen a couple of days ago is that while taking the bike down the stairs into the basement, the bike rolled off of the stairs, causing rhe rear wheel to drop about 4 feet to the ground. I then noticed the sound of metal bouncing around for a couple of seconds after rolling the bike forward. Not aure ifnit came from inside the motor or not.
Any thoughts on the issue or the correct next steps? Thanks.
KT LCD 5 controller
