How much beating can a hub take?
Pedrodemio   10 W
Post by Pedrodemio » Dec 30 2019 11:36pm
Hey guys, for a long time I've been thinking if switching my bike to a low power hub motor like the G310, I don't need much power, currently I run a friction drive with RC motors, but due to a bunch of factors the low speed torque is bad
What worries me is if they can take the way I ride, I like to make my commute fun by jumping wherever possible, take shortcuts through stairs and other obstacles that the city can offer, no massive jumps or anything too extreme
But I worry I would break the hub in little time, and to make it worse my bike ir a hard tail
What experience can you guys share?
Thanks
amberwolf   100 GW
Re: How much beating can a hub take?
Post by amberwolf » Dec 30 2019 11:46pm
In theory, the bearings on the axle should take the loading between hub cover and axle, but some people have discussed breakage of plastic gears inside geared hubs, or of teh clutch itself.
I'm not certain that's directly from the impact, but might rather be from the motor / wheel spinning really fast while in the air, then suddenly slamming to a near-stop upon impact, placing a lot of shear loading on the gear teeth and/or the clutch parts.
Sometimes motor axles are crappily made of crappy metals, and break from impacts. I've definitely had this happen at least once, I think it's contributed to at least one other such failure I had. Both of these were on a very heavy trike's rear wheels (both on the right side, which sees most of the potholes), and were from pothole impacts rather than jumps, but the effect is essentially the same as hard long jumps.
I expect that if you're not doing anything extreme, it's probably going to be ok with good quality (relatively) hubmotors, but I don't think there can be any guarantees. ;)
john61ct   1.21 GW
1.21 GW
Post by john61ct » Dec 31 2019 12:56am
Talk to Justin @ Grin
Mcdabber   1 µW
Post by Mcdabber » Dec 31 2019 3:28am
I ride my hub motor (qs205) pretty hard and so far its held up great. I mainly built my stealth clone to do wheelies but i have takin it off of a 3 foot high jump before and landing onto concrete. I also like to find as many jumps as possible around the city.
https://www.instagram.com/p/B5RRV4eJWQP ... _copy_link
Stealth clone, sabvoton 72150, qs205, 20s10p 25ah samsung 25r, 100amp BMS
dogman dan   100 GW
Post by dogman dan » Dec 31 2019 7:33am
A direct drive hub can take some severe beating, but big hucks are not really advisable. Meaning over 4 foot drops, particularly to flat landings. The danger is mostly to spokes and rim though, with a big DD motor like McDabber has.
With the smaller internal planetary gear hubs you have to be a bit more careful. When landing those, don't have the throttle on. landing with the throttle one puts a lot of shear on the cotter key that attaches the motor assembly to the shaft, and you can shear the key, or tear up gears themselves if the key doesn't fail first. With the throttle off, landing does not cause the shear, it should freewheel. It can be a hard motorcycle habit to break, landing with power on.
But yeah, small pops, stairs, they can be ok provided you don't ride around with broken or loose spokes. And yeah, shit can break anyway, like the alloy hub itself, where the spoke holes are, or the freewheel screws on. But often those failures do reveal a casting defect. I rode a trail once so rough, I loosened a lot of cover screws on the motor, and the derailleur fell off the bike. The motor overheated and got damaged wiring, but no problem with the spokes, rim, or motor itself.
Punx0r   100 GW
Post by Punx0r » Jan 02 2020 4:52am
The tyre/tube and rim seem to give out first. With a heavy hub the wheel hits bumps harder and it's more difficult to pop the rear wheel over them.
Pedrodemio   10 W
Post by Pedrodemio » Jan 03 2020 3:31pm
amberwolf wrote:
Dec 30 2019 11:46pm
It makes sense, in the way I ride it would be difficult to landing with the motor powered to happen
But the fact that there is an unknown and that if it broke would be expensive to fix makes me think that I should continue to pursue my RC motors based mid drive
john61ct wrote:
Dec 31 2019 12:56am
Will definitely send a message to them, but I expected to hear that isn't recommended since they are the ones selling
Mcdabber wrote:
Dec 31 2019 3:28am
This bike looks nice, I think having a rear suspension really helps to soften the load a bit
dogman dan wrote:
Dec 31 2019 7:33am
Thanks for the tips, I really feel I should go to another drive system. I always check my spokes, but to be honest I've been riding for the past months with one spoke less since it broke in the middle of a trail and I always forget to get it repaired
Punx0r wrote:
Jan 02 2020 4:52am
This is a concern, the weight making it way less maneuverable for climbing curbs and small stairs, I've never tried to jump a hub ebike since the ones I've ridden wasn't mine
j bjork   1 kW
Post by j bjork » Jan 05 2020 12:02pm
Mcdabber wrote:
Dec 31 2019 3:28am
Yes, they can take more than the Chinese rims.
It may be good for reference, but it was not those hubs that were in question here.
