PAS sensor acting weird?
costad   10 mW
Post by costad » Feb 07 2020 8:45pm
Hi,
I just replaced my old controller with a new Brainpower controller with throttle and LH100 screen on my bike. Everything is working fine, except for PAS.
I followed all the tips I could find about settings in the LCD screen, set to 12 magnets, PAS on, tried reversing the pedals etc, to no avail.
By accident i tried to move the pedals back and forth like a quarter of a turn a few times, and the motor started to run. The faster I go back and forth, the faster the motor is running.
Do you have any idea what the problem could be?
Links to what I have:
https://dyncdn.thg.dk/img/230224033_0_m_719_1200.JPG (PAS sensor)
https://www.amazon.co.uk/gp/product/B07 ... =UTF8&th=1 (Controller + Throttle)
E-HP   100 kW
Re: PAS sensor acting weird?
Post by E-HP » Feb 07 2020 8:59pm
Could be the distance between the magnets and sensor. Can you post a
Pic of your installation?
costad   10 mW
Post by costad » Feb 07 2020 9:07pm
I have already tried to press the sensor all the way up to the magnets, with a like 1mm gap between them, and it did not change anything.
Also, when I connect my old controller, everything is working fine again.
E-HP   100 kW
Post by E-HP » Feb 07 2020 9:21pm
costad wrote:
Feb 07 2020 9:07pm
Then a pic of the wiring and connectors for the PAS may help.
costad   10 mW
Post by costad » Feb 07 2020 9:40pm
Sure, I have taken a few pictures. Forgot to mention that the throttle is working fine.
aroundqube   1 kW
Post by aroundqube » Feb 07 2020 9:54pm
Sensor pickup can be directional . When you go back and forth with the pedal, and the motor works , it could be activating on the reverse stroke. If so , remove the 2 screws that hold the sensor to the mounting ring. Turn the sensor and wire 1/2 turn , and remount it .
costad   10 mW
Post by costad » Feb 07 2020 10:10pm
Stupid question, but doesn't it give the same result as reversing the pedals all the time? :oops:
E-HP   100 kW
Post by E-HP » Feb 07 2020 10:28pm
Even though it's likely that the red and black wires from the controller are +5V and GND, I'd check them with your voltmeter. Did you do any re-ordering of the wires to the connectors or just plug the PAS in?
costad   10 mW
Post by costad » Feb 07 2020 10:42pm
I had to switch the red and blue color from the controller, so the blue color is in the middle now.
I can measure 4.4V between red and gnd. Does it have to be +5V?
E-HP   100 kW
Post by E-HP » Feb 07 2020 10:56pm
costad wrote:
Feb 07 2020 10:42pm
No, +4.4V sounds right. Still could be the wiring order, but not as likely.
costad   10 mW
Post by costad » Feb 07 2020 11:38pm
I also just measured the PAS connection on the old controller, and it's 4.8v between red and black, so I guess the wiring is correct as they are placed identically as the new controller.
Also, the sensor is flashing red when i peddle forward at each magnet, and constantly lighting up when reversing if that's of any help.
E-HP   100 kW
Post by E-HP » Feb 08 2020 1:06am
What's the PAS level set to on the display when you're testing it?
costad   10 mW
Post by costad » Feb 08 2020 8:49am
I have tried both 1 and 24. 1 seems to be the most sentitive, so that's where it is now.
I bought a new sensor and magnet wheel today, and it's doing the same, so it's the controller, or somewhere in settings I guess
Roots Rocker   1 mW
Post by Roots Rocker » Feb 08 2020 10:09am
Hello,
Pedaling backwards and everything should work.
If so, swap magnetic orientation from Disk or install PAS System on other Side.
mfg Martin
costad   10 mW
Post by costad » Feb 08 2020 10:22am
No, pedaling backwards does not work. Whatever direction I pedal continuously does not work. I have to let the magnet move from left to right, and then from right to left over the sensor in a steady pace all the time to get my motor to start, just like when you paint a little piece of wood.
Yes, it's very weird :(
Roots Rocker   1 mW
Post by Roots Rocker » Feb 08 2020 12:10pm
Hello,
Wrong Sensor? XLD cannot handle any Type of DoubleHall Sensor, i.E. KT V12.
Try with a Standard 5-8 Magnets PAS Sytem.
mfg Martin
costad   10 mW
Post by costad » Feb 08 2020 7:17pm
Oh, so my 8 year old controller can do that, but not a brand new one.
Guess it's a really bad controller I found on Amazon. At least they could write about the compatibility stuff, so people don't waste time with this nonsense :(
Anyway, thanks for all your replies, I will try to find a 5 magnet one.
costad   10 mW
Post by costad » Feb 08 2020 8:02pm
So looking for a new sensor, but they don't really write whether it's single or dual hall.
Can I safely find a 5 or 8 magnet and assume it's single, or can they be dual as well?
