I'm looking to fit a 12 magnet disc to work with my LCD5 display - I currently have a 5 magnet disc.
The C1 settings allow selection of different numbers of magnets, as listed below.
Will the 05, 06 and 07 settings only work with sensors which detect reverse also? Or will these work with a straight 12 magnet disc & regular sensor?
Or
Does this mean that the maximum number of magnets I can use on a regular sensor is 10?
C1 parameter definition table:
KUNTENG power-assist sensors
Forward 5 Signal
00 Standard
01 Lower
02 Lowest
Forward 8 Signal
00 Higher
01 Standard
02 Lower
Forward 10 Signal
00 Highest
01 Higher
02 Standard
KUNTENG V12 power-assist sensors
Reverse 6 Signal
05 Standard
06 Lower
07 Lowest
Reverse 10 Signal
05 Higher
06 Standard
07 Lower
Reverse 12 Signal
05 Highest
06 Higher
07 Standard
Or
Forward 5 Signal
00 Standard
01 Lower
02 Lowest
Forward 8 Signal
00 Higher
01 Standard
02 Lower
Forward 10 Signal
00 Highest
01 Higher
02 Standard
Reverse 6 Signal
05 Standard
06 Lower
07 Lowest
Reverse 10 Signal
05 Higher
06 Standard
07 Lower
Reverse 12 Signal
05 Highest
06 Higher
07 Standard
