Cycle Analyst LCD screen busted
iacei   10 mW
Post by iacei » Feb 22 2020 5:12pm
Hi,
I smashed my CA 3 LCD screen. Everything still works but I can't see anymore.
I would like to change only the LCD, I am not bad at soldering.
Could someone tell me where I can order a compatible one?
amberwolf   100 GW
Re: Cycle Analyst LCD screen busted
Post by amberwolf » Feb 22 2020 5:21pm
have you checked with grin tech at http://ebikes.ca ? they probably keep spares around, if you can get them to reply to you. (i haven't been able to get a response lately)
if not, someone probably has a fried ca; v2 and v3 ls versions likely can use the same one (backlight may be different color).
NCC1941   100 mW
Post by NCC1941 » Feb 22 2020 5:27pm
Grin has replacement screens available for purchase here: https://www.ebikes.ca/shop/electric-bic ... splay.html
"The Kitchen Sink" - 2016 Surly ECR 29", 2WD Grin All-Axle + 9C RH212, 2x Phaserunner, 52v50Ah EM3ev (Rolling WIP)
"Novara Barrow eBike" - 2016 Novara Barrow Bike, Luna BBS02, 52v28Ah EM3ev (Retired)
iacei   10 mW
Post by iacei » Feb 23 2020 4:19am
Great news!
Thanks
I will do some pictures of the replacement and post them here
iacei   10 mW
Post by iacei » Feb 23 2020 4:21am
Damn.....18usd item and 33USD shipping to EU????
iacei   10 mW
Post by iacei » Mar 23 2020 12:58pm
Ok Folks, story is sad but can help you
1st: if you need a new screen just go to ebay and search for LCD 1602S and check the measurements you will find the LCD you need for the quarter of the price including shipping.
secondly, use flux + small heatgun otherwise you might end up like me with a busted CA3
So atm, I am waiting for my new CA3 to arrive because I don't know what went wrong with mine, components seem fine and LCD (expensive one from ebikes.ca) lights up.
amberwolf   100 GW
Post by amberwolf » Mar 23 2020 11:06pm
iacei wrote:
Mar 23 2020 12:58pm
"heatgun"?
do you mean soldering iron?
if you really mean heatgun, those will heat up *everything* including the mcu, probably to temperatures way beyond what they're designed to take, and probably for much longer than they could handle that.
so...it could just be a solder ball formed between smd leads/etc somewhere, and you could test for shorts between pins and pads and traces, with the continuity function of your multimeter if it has one (faster because it beeps when resistance is very very low, so you don't have to look at the display for every measurement). then just note down every short you find, and then ask ebikes.ca if there should be shorts between those or not. if not, you can try to check for solder bridges or balls that you can remove.
otherwise, it's more likely a heat-damaged component (the more complex, the more likely to fail, so teh mcu is the most likely failed part).
iacei   10 mW
Post by iacei » Mar 24 2020 4:37am
No, I really mean a smb heatgun
https://www.amazon.com/gp/product/B01GE ... 81d4235ee1
It is necessary when you want to desolder a component which is attached to many solder points and the LCD still sticks even when you used a desoldering pump before.
But I agree with my big heatgun, even if I did take precautions I surely damaged something
amberwolf   100 GW
Post by amberwolf » Mar 24 2020 11:14pm
ah.
well, with a damaged lcd you're going to toss after removing, it's much simpler if you just cut the pins between the lcd and the mcu board.
then desolder each pin individually, which shouldnt' take much heat or much effort.
once that's done, and the holes are clean enough to put the new lcd's pins thru, then solder each pin individually, which should work fine too.
alternately if you need the header itself, you can desolder it from the lcd side, because you're replacing the lcd, so it doesnt' matter what you do to that part. ;) just ensure whatever heat you use doesnt' affect the mcu board.
since the most likely failure is the mcu itself, you could ask grin tech if they sell just the programmed mcu--if so you could replace the one on the dead ca and see if it works now. :)
the other likely part failure is the pass transistor, which you can get from various electronics places. it's a different type of fet than usual, a depletion-mode, iirc (justin_le posted about it in one of the ca repair threads, possibly mine). if it is the pass transistor, then you could just try powering the ca from a 12v-15v source into the aux-power-input pin (cant' remember it's name, but it's listed on the pcb layout pic on teh ca info page).
iacei   10 mW
Post by iacei » Mar 25 2020 4:46am
Interesting, I'll try the aux-power-input but I cannot seem to find it on:
https://www.ebikes.ca/product-info/cycle-analyst-3.html
amberwolf   100 GW
Post by amberwolf » Mar 25 2020 5:24pm
apparently it doesn't have a pin in the headers for it (the one i was thinking of is for a sense line on a high voltage system, using a voltage divider).
but you can power by hooking 12v (not 12v-15v as i thought above) to the fet output pin; it's in this ca repair thread:
viewtopic.php?f=2&t=19540&start=25#p678269
basically will be the non-ground end of c5, which iirc is the big yellow tantalum cap, so the + end of that.
iacei   10 mW
Post by iacei » Mar 26 2020 4:05am
I have 12V on the LED+ pin so the voltage regulation works.
amberwolf   100 GW
Post by amberwolf » Mar 27 2020 11:40pm
do you also have voltages downstream? iirc there is a 5v regulator for the mcu / etc, somewhere just after the led/etc. can't remember where. been a long time since i poked around in there cuz of the smd stuff. :(
if there are voltages down stream including at the mcu pin for that (you can look up the spec sheet for that mcu to be sure where that is, but it's probably a corner pin, wiht the diametrically opposed corner being ground), then if you have an oscilloscope or a multimeter with a frequency check function, you can see if there are any signals coming out of any mcu pin, or at the clock pin (see if the oscillator is alive).
iacei   10 mW
Post by iacei » Mar 28 2020 11:35am
Ok so I get:
0V between V+ and Gnd on 1-2 from the main plug
12.9V on Led+ / GND
12.9V on 10V / Gnd
0V on the 5V from the throttle input
58V on the Red /GND on the PCB
Which component(s) must I change?
